Old 07-13-2006, 01:22 AM   #631
M7H
M7H's Avatar
Originally Posted by mxwrench
M7H, I think that only serpent OEM flyweights still are attached to the pin, everyone else uses floating flyweights. Just FYI.
That's true..... so maybe my theory only goes for Serpent clutches....
Originally Posted by afm
Centax flyweights are not attached to pins, they are guided by the pins during their expansion travel caused by centrifugal force.....
http://www.mytsn.com/publ/publ.asp?pid=11801
But let's make it simpler..............remember the standard clutches (purely centrifugal) before the Centax that are still used on 1/8 Off Road??......well the shoes are attached at one end by pins, so in order to tune engament you either change the springs for larger diameter, thus incrementing the tension, or you cut the flyweights to make them lighter (or both) in order to get a later engament at certain rpm's...opposite holds true for early engament....
AFM
Cutting the shoe, will also result in less surfaces touching the clutchbell, therefore more slip........
Or less weight in the shoe, which also results in more slip......
Serpent
M7H is offline   Reply With Quote
Old 07-13-2006, 06:50 AM   #632
afm
afm's Avatar
No, your theory is wrong......your link to Serpent's article proves my theory to be right....
Lighter (unweighted) flyweights engage later, but have a softer engagement (since more engine RPM is needed to get the same force as with heavy flyweights). By adding a weight (threaded setscrew) into the hole at the far end of the flyweight, the flyweight becomes heavier; it engages earlier and with more force.
(With heavier flyweights, you need more pre-tension force on the spring; this is one of the main reasons why it engages harder.)
Wrap-up
............expect the following:
* unweighted: later engagement, with less force
* weighted: earlier engagement, with more force
In the case of the off road clutches, you don't cut the shoes reducing the area that contacts the bell, you cut them on the inside (Dremel), and of course you do it as a last resource if you can't get a hard enough tension spring, and with experience you cut enough so as to avoid slippage.....but in the end you get same results........
AFM
afm is offline   Reply With Quote
Old 07-13-2006, 08:06 AM   #633
M7H
M7H's Avatar
I knowe, but still I read a article somewhere stating the opposite (lighter shoes engage earlier.....)
But, I can't prove that it's correct, so I will not believe that theory....
I know, I meant the same....
Serpent
Old 07-13-2006, 08:50 AM   #634
Nipple's Avatar
I think , assuming clutch spring tension remains the same, lighter clutch weight will result in later engagement.
Cos Force = Mass x Accelaration = Mass x velocity square / radius.
Since reduce in mass = reduce in Force to overcome the spring tension.
And to achieve same force but with reduced mass, that means velocity has to increase.
Just my 2 cents.
Nipple is offline   Reply With Quote
Old 07-13-2006, 08:56 AM   #635
Nipple's Avatar
And also bcos spring Tension = Spring constant x displacement.
As spring compresses the tension get larger (Who doesn't know that ), thus a lighter clutch weight will have a softer engagement cos it has less force and take longer time to fully overcome the spring tension.
Just my 2 cents again.
Old 07-13-2006, 03:39 PM   #636
SnakeEyz's Avatar
Has anyone in this thread run this motor with the skyline vr12 plus pipe and if so how was the performance.
Shepherd Velox V10/ KO Propo/ Novarossi Engines/ Team NLR/ V.O.R.R.A./ 301(Forever)/ AKA. Darryl Hurling
SnakeEyz is offline   Reply With Quote
Old 07-13-2006, 04:53 PM   #637
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
You can search right in the thread, check the top right of the post. Youll find some posts on the skyline pipe. From what Ive read and heard , it seems to work pretty well with the motor.
Artificial-I is offline   Reply With Quote
Old 07-13-2006, 05:38 PM   #638
mtveten's Avatar
Trader Rating: 27 (100%+)
The Vr12 + works better than any other pipe I have used with the motor.
mtveten is offline   Reply With Quote
Old 07-16-2006, 09:00 PM   #639
fastrcracer's Avatar
Default New WASP motor need help !!!!!!
Just got my new wasp installed into my RRR and started to break it in this weekend. I left the box settings on the motor and head shims as it came. I live in Louisville, Kentucky so the temp here has been in the 90's with high humidity. I was using the glow plug that came with the motor, a #6. I run 20% Trinity Platinum fuel with the RD Logics 6505 pipe. I couldn't get the motor to run at any lower than 230 degrees. The stock settings made the motor run very lean and I had to richen both the top and bottom to bring down the temp. Now the bottom end has a real bad bog after sitting for more than 5 seconds. After it cleans out it runs great, but no lower than 230. Any help would be appreciated !!!!!
Associated FT SC10
Futaba 3PK
AKA Tires
Maxamps Batteries
SRI Raceway, Louisville KY
fastrcracer is offline   Reply With Quote
Old 07-16-2006, 10:07 PM   #640
Z00M's Avatar
Trader Rating: 15 (100%+)
Sounds to me as though the motor is overgeared. Read back through this thread as rick howart and josh cyrul give their actual gearing numbers for the RRR.
My blog: http://mikesrc.wordpress.com
XRAY XB4
## NOSRAM ## XRAY ## KO ##
www.nbhc.com.au - www.teamxray.com
Z00M is offline   Reply With Quote
Old 07-16-2006, 10:14 PM   #641
Z00M's Avatar
After spending 4 hours last thursday trying different clutch and pipe combos I figured I hadn't learnt too much.
Racing yesterday at round 9 of the West Australian championship went fairly well. My G4S hooked up and the wasp delivered the goods to reset the 5 min qualifying record. Hopefully more improvements can be made in my setup, but so far so good with the CRF engine.
I guess I like this engine because of the challenge it presents in getting the harmony of components to make fast - and more importantly consistent - lap times.
We run on a very open, fast, flowing track however there are still places where maximum punch off the turn is required. While the CRF is not delivering that punch in spades, I feel I am getting closer to working out what the engine wants.
For the record, I lost the 10min A-main by 1 second, however it was 8 seconds faster over 10mins than I have ever been before.
Cheers,
Mike.
XRAY XB4
Old 07-17-2006, 12:19 AM   #642
Moderator
mxwrench's Avatar
First question:
Whats wrong with 230 deg?
BK
Brian Kinney
TLR Design Engineer
2016 Sponsors: Team Losi Racing, AKA Tires, Orion, Nitrotane, Horizon Hobbies, Fast RC Paint.
mxwrench is offline   Reply With Quote
Old 07-17-2006, 02:58 AM   #643
ziggy12345's Avatar
RTFM!! The manual say the operating temp is 257 deg F and thats what I run at. What % nitro you using? Mine bogs badly with 16% so I use 25%. I have removed 0.1mm shims and screwed in the middle needle 1/8th.
Cheers
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 07-17-2006, 03:26 AM   #644
at 230 degrees the engine is super rich on bottom. If it sets longer than 5 seconds it bogs and will die. If I lean it in any more to get the bog out then it starts getting hot, 265 and above.
The gearing could be off, but the problem I'm having is from idle to taking off.
It just seems that the motor is running to hot for how rich it is. Maybe it is just me.
Associated FT SC10
Futaba 3PK
AKA Tires
Maxamps Batteries
Old 07-17-2006, 10:06 AM   #645
ziggy12345's Avatar
Thats what happens to mine with 16% nitro. Try 25% and take 0.1mm out of the head
Cheers
Sponsored by:
Norfolk and Chance
Team Orion Wasp REV Nicolas Onroad Nitro Engine Zone 183 10-05-2006 09:04 AM
team orion wasp rev MAVICXXX Malaysian R/C Racers 31 09-19-2006 09:18 PM
Team Orion - Wasp!! BundyMan Onroad Nitro Engine Zone 1 03-03-2006 03:10 AM
Orion Element 19t Dyno results rinkrat99 Electric On-Road 7 10-09-2005 07:29 PM
Team Orion Wasp .12 HaLo_UsMc R/C Items: For Sale/Trade 6 03-16-2005 07:31 PM
