Team Orion CRF Wasp Rev X-Dyno results
#587
Service?
If you find a parts source - jump right in. Motor has huge potential - but this is a sure way to give it a bad reputation. With everyone running the wrong pipe/clutch config etc.
I have run it in with a RB pipe and a cobbled up clutch and it looks promising.
#589
Clutch
I ran a Serpent yellow shoe with weights cut and drilled from the old Serpent white sliding weights. New heavy spring etc. I never stressed the motor since I want to get the right bits - but it did not seem to have any holes in the power band. A bit like the ZX12 I thought.
#590
I wish i had a nice review to give but after about 30 - 40 seconds of running it locked up tight. pop the front bearing out and the crank is rubbing the case. the fit is just soooo tight right there. i called orion and sent it back to them 3 day ups. now i spoke to 2 other people who had the same problem. im sitting on a stack of engines im affraid to sell.
i can see it now. "sell engine, customer brings engine back, wants money back, i tell him he needs to send to orion, he tells me i suck and he's never coming back".
do i sell the engines i have or send them back to my distributor? i was so excited about this motor and to have such a let down like this i just sucks. good thing i still had my trusty mega zx-12.
later
Aldo
later
Aldo
#591
hi everyone. i just bought this motor and have 3 tanks through it. since the first tank the motor revs up after letting off full throttle. i no on a regular motor that means the low end it to lean but i keep richining the low but no help. it just doesnt sound normal but the temps are 198-203. any help please?? thanks
#595
Originally Posted by roadrage
no. i turned the idle way down and it still does it but if i blip the throttle it will stop. im not new at tuning a motor just this 1 is funny. riching the low-end doesnt help either.
BK
#596
My son and I both purchased the new Wasp and if we would've waited we would've made a different choice. The engine has great potential but is not suited for our cars. This engine requires the ability to gear way way down for tracks with under 215 foot straights, which are the majority of USA club tracks. The Kyosho, seems to be the only car that can get close with their gearing at present. TM said they will have the gearing issue rectfyied sometime in August.
Both engines are presently on the shelf waiting for new carbs. We broke the engines in using Josh Cyrul's break in process, with no problems, except my son's engine was a little more difficult to tune. Now I know why. We both ran two to three qualifieres till we couldn't keep them tuned. Seems the insulators were cracked and didn't exhibit any problems until the engine reached operating temp., Tried to over tighten the carb seat to seal better but that only lasted for 6 laps. Orion is aware of the cracked carb insulators and the leaky O ring seals. Quite a number are getting out of the factory with this problem. Once this happens, it's virtually impossible to pull the carb off. The part theat sucks is there are no parts support yet. I haven't heard if they have fixed these serious issues or if they are still shipping with same problems.
#597
And please, please remember that just because the engine doesn't have a pinch on the sleeve/piston assy, that doesn't mean you don't need to do break in. Some other critical parts still need time to seat themselves. ie. conrod bushing, bearings, crankshaft to crankcase fit, etc.
Believe me, you will be glad you spent the time to do it properly!
BK
#599
I had the first outing with the CRF on a nice big track on Sunday. It was the fastest engine on the track by a long way!! Low end can be taken care off by tuning the clutch
Cheers
Cheers
#600
Ziggy, is your engine EFRA legal?
