Old 06-28-2006, 12:07 PM   #556
ziggy12345's Avatar
Originally Posted by stefan
There were rumors when Jim Hottinger took over the US distribution for Top engines that he had some influence on the layout (timing) of the Top engines. Mine even had a silicone bed in the crank, which I never saw on a stock NR based engine before.
I had a Jim Hottinger moded TSR5 and it was ballistic!
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 06-28-2006, 12:15 PM   #557
Derby Bros Racing's Avatar
are the motors still backordered?
thx
Derby Bros Racing is offline   Reply With Quote
Old 06-28-2006, 03:41 PM   #558
GrandeGixxer's Avatar
Trader Rating: 15 (100%+)
Originally Posted by mtveten
Josh,
What are your thoughts on the different nitro percentages?
Currently I am running primarily on a 150x80ft track using 30% fuel. I get better miliage than all others and have excelent power.
If I were to switch to 20% what would I be giving up? what would I gain? How would the power band change assuming I had the engine tuned as good as it is now?
Does a lower nitro mix make the motor easier to tune?
Thanks,
Mark
Mark, on a smallish track like that, There is really no point in running 30%. You hsouldn't have any problem with running 20%.
Joe Cude
Mugen MBX-7R Mugen MTX-6R Mugen MTC-1 Mugen MRX-6 Mugen MST-1 Tamiya Euro Truck
GrandeGixxer is offline   Reply With Quote
Old 06-28-2006, 04:01 PM   #559
NiMo's Avatar
I always understood that it is the Nitro that cools the motor which is why we are restricted to 16% in the Uk.
So on a small tight track where you cannot get the speed to cool the motor would it not be best to run a higher Nitro content for cooling purposes, after all you can't use the revs the motor gives.
NiMo is offline   Reply With Quote
Old 06-28-2006, 04:17 PM   #560
Moderator
mxwrench's Avatar
NiMo, higher nitro content does not cool the engine, in fact it creates more heat. Basically, more nitro = more oxidiser to the methanol which in turn creates higher combustion pressures which create more heat.
On the other hand, higher oil content will cause cooler running, because the oil tends to help with heat transfer and expulsion, so the more oil the cooler the engine will run (to a point of course, too much oil will cause the mixture to be manditorially leaner to run properly, thus bringing the heat back)
BK
Brian Kinney
TLR Design Engineer
2016 Sponsors: Team Losi Racing, AKA Tires, Orion, Nitrotane, Horizon Hobbies, Fast RC Paint.
mxwrench is offline   Reply With Quote
Old 06-28-2006, 05:17 PM   #561
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
Seeing as how my tracks are abouit 190-200ft x 105 then definately 30 is a must.
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 06-28-2006, 06:58 PM   #562
I run 30%. I do however know a few very fast guys that run 20% Ira Shultz swears by it. He is fast. I also know some guys that run 40% and aren't very fast at all. I won't mention any names here.
Joe Cude
Old 06-28-2006, 07:17 PM   #563
HarKonnenD's Avatar
Pretty good. I noticed the 30% worked great for the engine up till a point. Though I like how the engine run hot and I have plenty power. Regardless my tracks arent the size of say Toledo or so.
Old 06-29-2006, 01:54 AM   #564
NiMo's Avatar
There is some video action from the Aldershot track over at 3hobby.net (see link below)
Go to the site, click on downloads (left side) and then on AMCC, then select your video (plenty there)
(You may need to log in to the site to get access)
Old 06-29-2006, 06:07 AM   #565
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
BK
Ive always thought the same (more heat, due to more power) , but I heard the same from a few people that 30% will run the motor cooler, which does kinda make sense. Thats why it seems to me a lot of the large monster class and buggies run 30% since they need more cooling due to the large mass they must propel and the fact that they arent always running a free flowing open track. Less cooling. But im not a fuel expert.
Another reason why I know people play with nitro percentages is to adjust fuel consumption. If your getting great fuel mileage might as well go up some to use it the excess fuel and put the motor to its best use for the time period on the track.
Artificial-I is offline   Reply With Quote
Old 06-29-2006, 05:39 PM   #566
impalabob64's Avatar
Send a message via AIM to impalabob64
Default Wasp Rev
Hey guys will running one of my Rev 12,s, of which i hve 3 of them i will be running at SuperiorHobbies in Orlando in will be in my new G4s an i will be running 40% nitro
RoninRc.com
MurnanModifiedMotors
Basher BT-4
impalabob64 is offline   Reply With Quote
Old 06-29-2006, 06:01 PM   #567
Moderator
Theyll have to put some extra support in those walls. That parkinglot track wont know what hit it...lol.
Old 06-29-2006, 07:00 PM   #568
Default Hey A-I
Whats man Bobby Watson yeah i know, tested the 40% in the Wasp ,man it just so dam much horsepower, it is insanly fast . Im running the Novarossi Fatpipe #2630 with short cronical header temped at 198 degress.gearing 18/51 23/46.
RoninRc.com
Basher BT-4
Old 06-29-2006, 07:24 PM   #569
I think you have been smoking too much cronic out of your pipe already.
Joe Cude
Old 06-29-2006, 07:32 PM   #570
Default Oops
sorry man, didnt mean to say that, just short header
RoninRc.com
Basher BT-4
Team Orion Wasp REV Nicolas Onroad Nitro Engine Zone 183 10-05-2006 09:04 AM
team orion wasp rev MAVICXXX Malaysian R/C Racers 31 09-19-2006 09:18 PM
Team Orion - Wasp!! BundyMan Onroad Nitro Engine Zone 1 03-03-2006 03:10 AM
Orion Element 19t Dyno results rinkrat99 Electric On-Road 7 10-09-2005 07:29 PM
Team Orion Wasp .12 HaLo_UsMc R/C Items: For Sale/Trade 6 03-16-2005 07:31 PM
