Old 06-24-2006, 02:05 AM   #496
NiMo's Avatar
Just got hold of one of these to try, good price, only 2/3rds the price of other motors from an official UK dealer.
Break in procedure?
Reading the manual, I understand it as :
Fit motor in car, start it up and drive, driving at slow race lap speeds using the revs but not hard acceleration, gradually bring to full race speed, all done in 3 or 4 tanks.
Is this correct?
NiMo is offline   Reply With Quote
Old 06-24-2006, 02:41 AM   #497
stefan's Avatar
Send a message via AIM to stefan
Josh and other CRF specialist,
my buddy Dongiganti asked me to clarify his question.
He's having trouble to get the engine warmed up.
It takes about 10 laps before the engine really makes power and then it runs reliably and fast. It usually comes off the track at 120 degrees C.
He's running 16% fuel and has already taken two 0.1mm shims out.
He's tempted to lean the engine to get it warmed up quicker,but he's concerned about overheating it.
Any ideas what he could change to fix this problem? Plugs probably, or leaner on the bottom?
In my opinion that sounds a bit like the Picco engines which also need a pretty long warm up time before they can be adjusted.
Any help would be appreciated
stefan is offline   Reply With Quote
Old 06-24-2006, 09:12 AM   #498
ziggy12345's Avatar
Break in procedure?
Is this correct?
Thats how i did mine! Try a strong clutch spring as it needs about 5K more revs to get off the line.
Cheers
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 06-24-2006, 12:48 PM   #499
Tommy Bergfeldt's Avatar
Send a message via ICQ to Tommy Bergfeldt
Me and 2 friends are also experiencing that the engine takes approximately 3 minutes to get to a temperature where the car even starts to shift gears.
JMI Motorsport / Red Bull Racing
HB Cyclone TC - Schumacher CAT SX & Cougar SV
Advanced Electronics - Autopartner.se - Sav÷x - NorthTQ
Tommy Bergfeldt is offline   Reply With Quote
Old 06-24-2006, 12:55 PM   #500
Originally Posted by HarKonnenD
Good idea.
DOnt worry, when we git out there u will see how fast it is
CHUCKMANDO is offline   Reply With Quote
Old 06-24-2006, 04:27 PM   #501
ziggy12345's Avatar
Mines like a startled deer right from the first lap!!
Sponsored by:
Norfolk and Chance
Old 06-25-2006, 04:51 AM   #502
Send a message via ICQ to _cyclops_
Originally Posted by M7H
Just to give you an example:
Jilles Groskamp, 1 of the worlds best drivers in the electic scene, drove the 720 during the EFRA GP held in Holland.
He for the first time drove this car on Thursday, and this really was the first time he EVER drove a 1/10 scaled gas powered car.
after Qualifying on Saturday, he secured 2nd qualifing time........
Ok, he was farmiliar with the track, this helps......
Sorry? He drove like 500 laps.. that's where the fist 'spy shots' of the 720 came from... pay attention
_cyclops_ is offline   Reply With Quote
Old 06-25-2006, 05:44 AM   #503
Schrijver99's Avatar
And don't forget Lisse where he drove Rob Kuijper's car at the Indoor (a few year back, Serpent 705)
Back on topic:
I can't wait for my CRF to arive and see what it can do at the kypsho cup here in the Netherlands
Schrijver99 is offline   Reply With Quote
Old 06-25-2006, 04:42 PM   #504
M7H
M7H's Avatar
Missed that one, really thought that Rene did those laps.....
Serpent
M7H is offline   Reply With Quote
Old 06-26-2006, 03:18 AM   #505
NiMo's Avatar
This is a big track motor, more so than a Sirio.
I can't gear my G4S low enough to use the revs (already on 18/23) and it bogs badly out of the tight corners after 6 laps (overheating?).
I tried a tighter and stiffer clutch spring but lost that low end drive needed for the infield making it unusable.
Current gearing with this motor almost lets me run the 155ft main straight in 1st gear (does about 140ft), so I need to lower the rev range.
Would a longer manifold be the answer?
Old 06-26-2006, 07:05 AM   #506
ziggy12345's Avatar
Hi
Are you using 16% fuel? I tried mine and it doesnt like it. I suggest going to 25% or removing 0.1 or 0.2mm shims from the head. To get the top revs you need to have the motor dialed with the correct pipe so you have enough useable rev range.
Sponsored by:
Norfolk and Chance
Old 06-26-2006, 07:24 AM   #507
NiMo's Avatar
Originally Posted by ziggy12345
Hi
loads of top revs, motor really screams, it's the bottom end I need with a drivable clutch.
Think I may have to bin this motor and get one I know works, a JP.
Old 06-26-2006, 07:32 AM   #508
Josh Cyrul's Avatar
stephan - It sounds like the engine is just too rich on the bottom end. My engine at the ROAR Nats would warm up for 30-60 seconds in the pits, set it down on the track and it would shift down the straight the very first lap!! This was only after I leaned the bottom end as it should be though. If the bottom was too rich, then I had the top lean to compensate and it did take a long time to come up to a stable temp. Once I leaned the bottom, I ended up richening the top end slightly and the engine had a lot more power than it had before. Again, the sounds this engine makes are really different compared to other engines so it does take a little time to understand the sounds and settings needed to make the engine really scream!!
NiMo - The small clutch that is in the G4 makes tuning the clutch very difficult. I would check and see if the new CRF Clutch kit for the Serpent car will fit in the G4 (I think it will). I know this in itself would help a TON!!! A longer manifold would probably help....
Ziggy12345 - What plug are you using?? For 25% and higher I would use either the #6 or #7. If you are running 16% you might want to run the #5 or #6. The #7 with 16% can be a bit too cold of a plug - I would only use this in 90F+ weather....
Destiny, Ko Propo, Hobby Wing, Ulti Racing Tires, Protoform, Xenon Racing, Pivothead, Vizon, TQ Wire & Hella Graphics
Josh Cyrul is offline   Reply With Quote
Old 06-26-2006, 07:56 AM   #509
NiMo's Avatar
I will try the longer pipe, and also try taking some weights out of the clutch.
Flywheel on G4S very small (30.5mm), RRR/FW05 flywheel 33mm would be below chassis bottom, otherwise I would have tried the Kyosho 3D clutch which I understand properly.
Old 06-26-2006, 08:20 AM   #510
ziggy12345's Avatar
I was using the plug that was in the engine that came with it, I'm not sure what one it is. I am waiting for the CRF plugs before I change it as I dont know if the Nova ones have the correct seal angle, somebody saif the OS ones are the same.
FYI Nimo. Mark Christopher had the fastest car on the track at Ashby running a JP T03M out of the box!!
Sponsored by:
Norfolk and Chance
Team Orion Wasp REV Nicolas Onroad Nitro Engine Zone 183 10-05-2006 09:04 AM
team orion wasp rev MAVICXXX Malaysian R/C Racers 31 09-19-2006 09:18 PM
Team Orion - Wasp!! BundyMan Onroad Nitro Engine Zone 1 03-03-2006 03:10 AM
Orion Element 19t Dyno results rinkrat99 Electric On-Road 7 10-09-2005 07:29 PM
Team Orion Wasp .12 HaLo_UsMc R/C Items: For Sale/Trade 6 03-16-2005 07:31 PM
