Old 06-21-2006, 11:24 AM   #481
Originally Posted by Josh Cyrul
Artificial-I and Huse - Mike, did you try the Orion shoe?? The Mugen/Kyosho type Grey clutch shoes are more aggressive than the Yellow but I'm pretty sure that our Orion/CRF shoe is less aggressive than the Yellow... I didn't have any yellow ones to compare against so I may be wrong....
M7H - Again, it's cool to hear about the breakin being so popular and people are having sucess with it. No royalties needed - If it works and they have a good experience then that means more people racing, more people racing = more fun and competition!! I think that's enough of a royalty there in itself!! I guess I'll have to test a bit and do a new REV break-in procedure to get the most from this engine!!!
Josh, I did not get a chance to try the orion shoe at the nats, but plan to try it with Brian at the RC pro series race in 2 weeks.
Mike.
mhuse6969 is offline   Reply With Quote
Old 06-21-2006, 12:40 PM   #482
M7H
M7H's Avatar
Please do, because You already see the amount of question raising, it will only clarify things for this engine....
I understand that it has NO piston/liner binding when new, so break in is only required for the conrod and bearings?
But when you post a break-in procedure, I will forward it to some Dutch forums.......
Serpent
M7H is offline   Reply With Quote
Old 06-21-2006, 03:23 PM   #483
stefan's Avatar
Send a message via AIM to stefan
Originally Posted by M7H
I rest my case...
Please do!!!!
Btw, Orange didn't look like a very bright color tonight, did it?
stefan is offline   Reply With Quote
Old 06-21-2006, 03:29 PM   #484
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
Josh: What shoe were you running? I guess the CRF.
Im guessing maybe with all the power the yellow's will work better as they get 2-3 times more run time out of them then? Maybe the motor needs some slip otherwise the car would be loosing traction?
Artificial-I is offline   Reply With Quote
Old 06-21-2006, 04:04 PM   #485
M7H
M7H's Avatar
Originally Posted by stefan
Please do!!!!
Time wil tell.......
With 5 basic players not playing, I think they did a good job, and.......
we now made it possible for Germany to get to the final before we meet eachother...
Serpent
Old 06-22-2006, 01:42 AM   #486
MCRUZ's Avatar
Thumbs up Thanks
Josh, it was a pleasure getting to know you this past weekend and the nats. Thanks for all you help. Marc
M32EVOX
MCRUZ is offline   Reply With Quote
Old 06-22-2006, 03:49 PM   #487
ziggy12345's Avatar
Ran the wasp for the first time today and it went well. I had to incease the gearing and loosen the clutch as the engine had so much torque. The engine was reving out on the straight but the top speed was way more than I have had before.
I also ran the Murnan LL3 and the wasp had the edge
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 06-22-2006, 05:56 PM   #488
GrandeGixxer's Avatar
Trader Rating: 15 (100%+)
So, is there anywhere that actually has the motors and clutch and plugs in stock?
Joe Cude
Mugen MBX-7R Mugen MTX-6R Mugen MTC-1 Mugen MRX-6 Mugen MST-1 Tamiya Euro Truck
GrandeGixxer is offline   Reply With Quote
Old 06-22-2006, 06:08 PM   #489
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
Man I'm wondering what engine to get..arg....either this engine or something...decisions decisions.
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 06-22-2006, 06:10 PM   #490
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
The motor seems fast (saw it at the Nats) but I would hold off on getting one to wait and see how long they last.
Racing4Evo is offline   Reply With Quote
Old 06-22-2006, 07:13 PM   #491
HarKonnenD's Avatar
Good idea.
Old 06-23-2006, 08:06 AM   #492
Josh, what was your setting for the CRF Kyosho clutch ? And how was the feeling vs the original RRR clutch ?
Thanks and congratulation for your victory !
barclayrc is offline   Reply With Quote
Old 06-23-2006, 09:39 AM   #493
Josh Cyrul's Avatar
barclayrc:
CRF Weight - 2 set-screws
CRF Spring - Tightened to 1.6mm
CRF Shoe - .5-.6mm gap
If you are doing a straight pull off of a hairpin corner, there isn't much difference between to stock Kyosho and the CRF clutch. There is a big difference though any where that you are on-throttle going through a casousel and/or shifting into 2nd while turning (car/clutch/engine are loaded). The CRF clutch simply has more power/pull through those sections and into 2nd gear.
Destiny, Ko Propo, Hobby Wing, Ulti Racing Tires, Protoform, Xenon Racing, Pivothead, Vizon, TQ Wire & Hella Graphics
Josh Cyrul is offline   Reply With Quote
Old 06-23-2006, 12:50 PM   #494
Hello, I have a problem with the CRF engine. I use gasoline with 16% Nitro and have already 2/10 seal removed, nevertheless need the engine approx.. 10 rounds on track by itself freely to run. The engine switches before not times in the 2. Course. After approx. 1o the engine catches and runs rounds freely to turn off on then with 120 Celsius. What do I have to change around to turn off?
Greets Markus
Dongiganti is offline   Reply With Quote
Old 06-23-2006, 11:52 PM   #495
stefan's Avatar
Greets Markus
Hallo Langer,
das ist leider nicht sehr verstaendlich. Was wolltest du denn wissen, dann uebersetze ich"s fuer dich.
Was ich verstanden habe ist glaube ich, dass der Motor 10 Runden braucht bis er warm ist und dann gut laeuft, aber am Ende 120Grad hat, ist das richtig?
Schreib"s als PM
Team Orion Wasp REV Nicolas Onroad Nitro Engine Zone 183 10-05-2006 09:04 AM
team orion wasp rev MAVICXXX Malaysian R/C Racers 31 09-19-2006 09:18 PM
Team Orion - Wasp!! BundyMan Onroad Nitro Engine Zone 1 03-03-2006 03:10 AM
Orion Element 19t Dyno results rinkrat99 Electric On-Road 7 10-09-2005 07:29 PM
Team Orion Wasp .12 HaLo_UsMc R/C Items: For Sale/Trade 6 03-16-2005 07:31 PM
