Old 06-14-2006, 03:06 PM   #391
For those of you that do not like the power band higher think about this:
In full scale racing the goal is always to raise the peak power numbers to a higher number and a higher rpm range, than you put more gear in and the results is more power to the tires, even if the power is the same. It is simple math, same power, more gear, more power to tires. That is why F1 runs 18,000 to 20,000 rpm and why NASCAR engines now have peak power at 8500 rpm when it was 7500 just a few years ago. In NASCAR it is so important that they put a gear rule in place to keep the rpm's in check.
Take the higher rpm's add gear and go faster, it works!
OldNSlow2 is offline   Reply With Quote
Old 06-14-2006, 03:16 PM   #392
Derby Bros Racing's Avatar
remember, adding gear will make the bottom suffer, which a bunch of people here are saying they are experiencing.
i don't have the motor and i haven't used it myself. but a fellow racer was running one last week and i don't see the bottom suffering at all. we have a very technical track where it requires a lot of torque out of the corners (slow turns so acceleration is a must). his car takes off pretty quick and quicker than my OS. he was using a VR12Plus pipe.
Derby Bros Racing is offline   Reply With Quote
Old 06-14-2006, 03:44 PM   #393
I think we are saying the same thing, adding gear in my example means a lower gear (higher number). Different forms of racing use different terms for talking gear ratio. In my world of full size racing when we say add gear or shorter gear means bigger number for ratio. Taller gear is smaller number.
Now I am confused......LOL
Old 06-14-2006, 03:53 PM   #394
B4
B4's Avatar
Originally Posted by Z00M
The list price for the motor is A$425. If you can't get it for that price then let me know and I'll sort you out. Even I missed out on one of the first batch to arrive in Aus. You'll probably find that there is nil stock in the US as well (anyone can correct me if I'm wrong).
Cheers,
Mike.
Hi Mike,
I can't get it for that price. Your help would be appreciated.
Simon
B4 is offline   Reply With Quote
Old 06-15-2006, 01:58 AM   #395
Schrijver99's Avatar
Does anybody know the difference between:
ORI81308 WASP Rev CRF .12 Cylinder Head 6 fin
and
ORI81340 WASP Rev CRF .12 Cylinder Head 6 Fin Monoblock
Schrijver99 is offline   Reply With Quote
Old 06-15-2006, 05:50 AM   #396
Nano's Avatar
and
While designing the engine 2 cooling solutions were tested for the cylinder head, one with two different parts, button head+cooling head, and one with only one part, engine head with cooling fins in one piece.
The one piece design has a better cooling capability and could be usefull in extreme heat conditions. That is why we decided to offer it as an optional. However it is not required 99.99% of the time, unless maybe you live in the desert or something like that
ORI81308 is the original part.
Nano is offline   Reply With Quote
Old 06-15-2006, 05:54 AM   #397
itchy b's Avatar
australia is mostly desert
-Blitz-Rallyhawk-EX 1.5R-Xpress-P64 Tyrrell-Lotus79-Espirit VTA
EX1.5-SC10 4x4
itchy b is offline   Reply With Quote
Old 06-15-2006, 05:58 AM   #398
B4
B4's Avatar
But not where we race.
Old 06-15-2006, 08:08 AM   #399
fastrcracer's Avatar
Where in the US or online can you buy the Wasp Rev 12 and CRF pipes ?
My LHS still has the motors on backorder from Horizon.
Associated FT SC10
Futaba 3PK
AKA Tires
Maxamps Batteries
SRI Raceway, Louisville KY
fastrcracer is offline   Reply With Quote
Old 06-15-2006, 08:10 AM   #400
R/C Tech Charter Subscriber
The last place that had the motors in the US was HRP and my LHS got the last one for a special order. The pipes are not available yet.
NismoSkyline17 is offline   Reply With Quote
Old 06-15-2006, 08:29 AM   #401
thanks
Associated FT SC10
Futaba 3PK
AKA Tires
Maxamps Batteries
Old 06-15-2006, 09:20 AM   #402
Smile
In a previous post Nano said that they should be today in the USA and that you should contact [email protected] to have informations on where to get pipes and plugs
barclayrc is offline   Reply With Quote
Old 06-15-2006, 10:53 AM   #403
All the pictures of the CRF clutch sets ans spares can be found here : http://www.teamorion.com/Products/Nitro+Clutches
Old 06-15-2006, 12:50 PM   #404
rmdhawaii's Avatar
Has any testing been done with the Kyosho lightweight flywheel and clutch bell? Also, what is the best application of the weights? Are all nine intended to be used or are there instances when you would only use none, one or two? Does the parts ship with some type of instruction sheet? If so, could we see a copy.
I think this is the first time I've heard of the V6 CRF Clutch. Is this applicable to on-road vehicles? The way it's written up, one might get the impression that it's for off-road vehicles.
Thanks!
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 06-15-2006, 01:54 PM   #405
Nano's Avatar
rmd,
I think that the testing was made with the original flywheel and clutch bell but I'm not sure. The clutch was designed with all weights fitted at all times. We will have some form of instructions for the clutch with as many info as possible.
Josh and the rest of the team will be using the CRF clutch parts at the nationals this week-end.
This is what Josh wrote in his report about clutch testing : "Next, I tested with the clutch parts from Fabrice. I started with the settings as you said and it was quite good. I only made a small adjustment (clutch nut to 1.6mm) and the clutch was perfect!! Good power, nice to drive and extremely consistant!!"
Important is also the shoe/clutch bell clearance which has to be 0,5 - 0,6 mm
The CRF V6 clutch is originally meant for off-road cars (1/8th and Monster Trucks). It was also designed by the guy that designed the motor, he felt that he had to improve the clutch designs that existed because he was not satisfied with them He runs one on the Wasp .12 that is fitted to his 1/8 scale buggy
Team Orion Wasp REV Nicolas Onroad Nitro Engine Zone 183 10-05-2006 09:04 AM
team orion wasp rev MAVICXXX Malaysian R/C Racers 31 09-19-2006 09:18 PM
Team Orion - Wasp!! BundyMan Onroad Nitro Engine Zone 1 03-03-2006 03:10 AM
Orion Element 19t Dyno results rinkrat99 Electric On-Road 7 10-09-2005 07:29 PM
Team Orion Wasp .12 HaLo_UsMc R/C Items: For Sale/Trade 6 03-16-2005 07:31 PM
