Old 06-08-2006, 01:52 PM   #301
afm
afm's Avatar
Originally Posted by Josh Cyrul
.....afm - I think that means operating temperature but I will check to be sure - I think it's listed backwards from normal which indicates the plug temp.
Thaks Josh, we'll wait for your comfirmation..... BTW best luck on the Nationals
AFM
afm is offline   Reply With Quote
Old 06-08-2006, 02:00 PM   #302
rmdhawaii's Avatar
rmd - Evo3.... I've never run the STI. Lap time was nearly identical but with the fuel milage difference I was 8 seconds faster over 30 minutes... Now that we are learning about the pipes, I expect the lap times to be faster with still keeping the fuel milage difference in tact... I'll know more after this weekend.
Thanks for sharing! That's a really good baseline comparison. Given that your Evo3 was probably fully tuned and running the most optimal pipe, that's saying a lot.
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 06-08-2006, 02:03 PM   #303
Originally Posted by mugen.racer
were can i buy crf pipes from need pipes ASAP CAN SPME ONE HELP ?
You should check for distributors on www.teamorion.com
WorldCup2004 is offline   Reply With Quote
Old 06-08-2006, 03:23 PM   #304
rmdhawaii's Avatar
I just got off the phone with Ultimate Hobbies and they don't have the plugs or the pipes. With regard to the pipes, they said they don't know if they are going to carry it yet. I informed them that the engine will perform best with the pipes made for the engine and the response was, "So they claim. We haven't tested it ourselves yet."
Great. Just great.
Old 06-08-2006, 03:39 PM   #305
You should call Team Orion USA !
barclayrc is offline   Reply With Quote
Old 06-08-2006, 04:27 PM   #306
That is a pointless comparison ! Firstly EVO 3 is older and there is now a STI. Why not compare the Evo 3 to the old WASP? Secondly, the opinion is going to be very biased towards the sponsor (Josh, im not questioning your integrity), and thats the way the commercial world works. If you asked Adrien Bertin the same questions, no doubt the Sirio would yield the best results, or Mike Swauger would tell you that Ninja works the best for him and so on!!!
Even though im all Sirio, I still support team orion, and would like to try a CRF soon. As for optimal pipe with the EVO 3, in my opinion, it's not the Sirio 2611 EFRA but rather the Mugen 2501. Better fuel consumption as well as more power.
Rody is offline   Reply With Quote
Old 06-08-2006, 04:55 PM   #307
rmdhawaii's Avatar
Old 06-08-2006, 05:05 PM   #308
rmdhawaii's Avatar
To each his own. I know a few A Main guys that are using the Evo3, so it means something to me. Plus, I said baseline comparison, you know - a known quantity that you can compare something against.
I don't expect Josh to test every engine against the WR.
Old 06-09-2006, 04:43 AM   #309
Nano's Avatar
Originally Posted by afm
Nano
On the new web site they print the plugs like this:
ORI88825 CRF Turbo Plug 5 COLD ???
ORI88826 CRF Turbo Plug 6 MEDIUM
ORI88827 CRF Turbo Plug 7 HOT ???
I'm confused ??? shouldn't the higher number be the coldest??? or in this item Orion also makes a difference....????
AFM
The text has been changed and it's right now, sorry for the mistake
Nano is offline   Reply With Quote
Old 06-09-2006, 06:37 AM   #310
BRT
Here you have the new Orion CRF clutch, references and photos:
More info and bigger photos:
http://www.cochesrc.com/article1353.html
http://www.cochesrc.com/foros/ftopic57734-200.html
In that forum post (spanish) we are speaking about this engine, and there are interesting conclusions, but we have to do more tests.
BRT is offline   Reply With Quote
Old 06-09-2006, 07:26 AM   #311
Nano's Avatar
Wow that was fast!
Yes this is one of the clutch sets made by CRF that will allow you to fine tune your original clutch for the Wasp CRF engine. Designed, tested and approved by the CRF development team! Notice the square wire spring.
Old 06-09-2006, 07:48 AM   #312
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
Originally Posted by Nano
Wow that was fast!
How much will it cost as a whole. And will there be spare parts for it?
eBay user id: riketsukirai
Riketsu is offline   Reply With Quote
Old 06-09-2006, 10:37 AM   #313
rmdhawaii's Avatar
Nano: Are the clutch sets applicable to all track conditions? (i.e. small, medium, large - technical/non-technical) I also noticed that the square spring can be purchased seperately. Does that mean that the specific car clutch sets use a different springs?
Is flywheel binding that much of an issue? When are people experiencing this problem and is it that common? What is the best way to deal with the problem until the clutch sets become available?
Thanks!
Clutches, we are preparing special tuning sets for different types of clutches, They include special weights using very hard material to limit binding on the flywheel, a shoe made out of a selected type of teflon and most importantly a special spring made with square wire. With this setup you will get the best clutch function for this engine.
Old 06-09-2006, 12:26 PM   #314
BRT
Old 06-09-2006, 01:03 PM   #315
rmdhawaii's Avatar
Nano: I'm planning on getting the ORI88003 Torque/Speed pipe, but could you provide more details on the ORI88002 High Torque pipe? How are "small tracks" being defined?
Thanks!
Team Orion Wasp REV Nicolas Onroad Nitro Engine Zone 183 10-05-2006 09:04 AM
team orion wasp rev MAVICXXX Malaysian R/C Racers 31 09-19-2006 09:18 PM
Team Orion - Wasp!! BundyMan Onroad Nitro Engine Zone 1 03-03-2006 03:10 AM
Orion Element 19t Dyno results rinkrat99 Electric On-Road 7 10-09-2005 07:29 PM
Team Orion Wasp .12 HaLo_UsMc R/C Items: For Sale/Trade 6 03-16-2005 07:31 PM
