Team Orion CRF Wasp Rev X-Dyno results
#241
Originally Posted by Rody
That team Orion Pipe looks to be the same as the Mugen 2501 pipe made by M Mielke. Great pipe.
#242
Originally Posted by corallyman
Nano,
Which clutch type of the 3 you mentioned would work with the Team Magic G4s car.
Steve
Steve
#243
Originally Posted by silverM3
How much are you guys paying for this engine? Most of the places selling it over $300. I think this is a bit overpriced. For this price, I can get a new NovaRossi 12 plus 3 Ceramic. What is the MSRP for it? thx.
#244
Originally Posted by ziggy12345
Is there room in the engine to lower the sleeve by 0.3mm on this engine? I was thinking of trying a mod where I skim 0.3mm off the bottom of the sleeve flange to adjust the port timing.
If you get a BRB set it comes with 0.3mm of undersleeve shims (3 x 0.1mm) so you can raise the sleeve. Raising the sleeve moves the power band up the curve so for fast tracks you add shims and tight tracks take them out. I was hoping I could do the same to the CRF
Cheers
Cheers
#245
Originally Posted by Nano
It is manufactured by Mielke, but it's a CRF design optimized for the Wasp engine.
#246
A lot of testing has been made on a small indoor track and in these conditions the engine has way enough power so it was assumed that it wouldn't be needed to lower the sleeve. Shimming under the sleeve can be done to increase top end though.
Cheers
#247
ziggy, nothing to doubt, just check the dyno testing and test results made by Josh ! I saw the engine in use and I can tell you, the question is not the burn speed of methanol but more to practice enough to be able to drive the car with so much power !!!!
#249
Overpriced? with this engine you get something that has as much or even more power than a super modified engine that you will pay 500$+ for. Without talking about the technology inside...
I am not going to talk about pricing or power, but defenetly want to talk about technology. What different technology are you talking about inside the engine? beside Nikasil plating-which also been use in the past in some of OS and Zenoah RC engines. BTW, Nikasil is not 2-3 times harder then Chrome plating, just about 7-9 % and mostly use in automotive and other industries to coat Al alloys, but it is defenetly much easier to implement in high speed manufacturing-chrome plating required much more waste managment technologies and more expencive.
Beside that I didn't see different in TECHNOLOGY inside engine compare to any other brand.
#250
Edward have you already seen how the engine is made, it is totally new technology. Check the video they made !
A Vickers Harness test was done between cylinders of hard chrome vs. NikaSil
Hard chrome was approximately 600.
NikaSil was about 1180. Almost twice as hard.
#251
May be you mean design-but it is not technology-it is different design
Check this web site for reference I just found http://www.eci2fly.com/pages/products_Ni+C.aspx
#253
Originally Posted by mxwrench
Eduard, you are such a KILLJOY!!!
Se ya this weekend!
Se ya this weekend!
#254
Ok so new technology for RC engines that no one else thought of or was able to implement in RC engines, in order to get superior performance, efficiency and durability. How does that sound
