Old 06-03-2006, 09:33 PM   #181
Moderator
mxwrench's Avatar
Also, gearing wise for everyone out there: If you try one of these motors you really need to adjust the GEARING!!!
I ran today down in Toledo where I have a ton of laps. The engine was working well but seemed a bit off of what it could be. I dropped the gear and the engine was soooo much better!!! It was like I dropped in a new motor. Everyone remember, this engine likes to REV so be careful to not hand too much gear on it.
Gearing for past engines @ Toledo:
17 / 23 Pinion
61 / 56 Spur
Gearing for Wasp REV @ Toledo:
16 / 22 Pinion
59 / 56 Spur
Keep this in mind when you hit your home tracks to test out the engine!!
I second that!!
I ran some more today @ Crystal Park and found the same to be true.
I might add also:
Run your clutch a little tighter than you would normally too. This helps the engine come into the 'sweet spot' much easier without any hesitation.
My normal clutch spring setting
Kyosho red 1/8 spring @ 2.0mm preload
My Wasp clutch setting
Kyosho red 1/8 spring @ 2.20mm preload
I am running similar gearing as Josh
16/22 pinion 59/55 spur
This is with 60mm rear tires and 58mm front tires
BK
Brian Kinney
TLR Design Engineer
2016 Sponsors: Team Losi Racing, AKA Tires, Orion, Nitrotane, Horizon Hobbies, Fast RC Paint.
mxwrench is offline   Reply With Quote
Old 06-03-2006, 10:20 PM   #182
jag
jag's Avatar
Any idea how much timing this thing has? The crank window looks to be 1/2 the total diameter... and that exhaust port Looks very cool. I might have to try one out.
jag is offline   Reply With Quote
Old 06-03-2006, 11:47 PM   #183
Hello, I am new on this forum, I am from Europe. I would like to ask Josh which pipe you are using and which plug.
And how is your engine power compare to others since you have been at Toledo ?
Thanks for your time.
barclayrc is offline   Reply With Quote
Old 06-04-2006, 05:03 AM   #184
B4
B4's Avatar
Anyone know when this engine is going to be available in HongKong or Japan. the only place I have seen it is RC-Mushroom and even they show it out of stock.
If you know where it's available could you please post a link.
B4 is offline   Reply With Quote
Old 06-04-2006, 05:48 AM   #185
You should check with Tecrotec in Spain
Old 06-04-2006, 06:42 AM   #186
EdwardN's Avatar
If I am not wrong, induction open at 15 ABDC and close 70 ATDC, transfer 124 and exhaust 172.
Edward
DISCLAIMER: Since 90% of my posts may be BS, and since my posts may be either insanely idiotic, incoherent, and/or not even close to a rational thought, please accord my posts no more than 10% of credibility.
EdwardN is offline   Reply With Quote
Old 06-04-2006, 07:15 AM   #187
Rick Hohwart's Avatar
Additional engines will be shipped this week. Great Planes/Tower, Horizon, and Ultimate Hobbies will get more. As of right now, HRP Distributing still has about 10 in stock. They do not sell direct to the public, but your local hobby shop can order one from them.
Rick Hohwart is offline   Reply With Quote
Old 06-04-2006, 09:56 AM   #188
Default Plugs
Rick, Not sure if I missed it, but what is the deal with the glow plugs. Can we use others like rex or os till my lhs gets in the orion plugs?
CHUCKMANDO is offline   Reply With Quote
Old 06-04-2006, 09:59 AM   #189
gfd2726's Avatar
Send a message via AIM to gfd2726
I saw a post a while back that O.S turbo plugs will fit but I may be wrong.
gfd2726 is offline   Reply With Quote
Old 06-04-2006, 10:02 AM   #190
They will. We suggest the Orion plugs becasue they will produce slightly more power.
Old 06-04-2006, 10:11 AM   #191
Thanks for the replies, I will get a couple of OS in the meantime.
Anyone know who has the plugs as of now?
Old 06-04-2006, 12:33 PM   #192
gfd2726's Avatar
RC-Toro has them in stock but they only sell in a set (5 plugs).
Old 06-04-2006, 01:57 PM   #193
mtveten's Avatar
Trader Rating: 27 (100%+)
Rick,
What is the difference between the Orion #6 turbo plug (p/n ORN88811) and the #6 turbo plug (p/n ORI88826) listed in the CRF manual.
When will the plugs listed in the CRF manual be available from Great Planes & Horizon?
Mark
mtveten is offline   Reply With Quote
Old 06-04-2006, 05:23 PM   #194
Sorry,
I meant who has the team orion plugs in stock.
Old 06-04-2006, 07:30 PM   #195
Regional Moderator
daniz24's Avatar
Whats the street price for this engine??
daniz24 is offline   Reply With Quote
Team Orion Wasp REV Nicolas Onroad Nitro Engine Zone 183 10-05-2006 09:04 AM
team orion wasp rev MAVICXXX Malaysian R/C Racers 31 09-19-2006 09:18 PM
Team Orion - Wasp!! BundyMan Onroad Nitro Engine Zone 1 03-03-2006 03:10 AM
Orion Element 19t Dyno results rinkrat99 Electric On-Road 7 10-09-2005 07:29 PM
Team Orion Wasp .12 HaLo_UsMc R/C Items: For Sale/Trade 6 03-16-2005 07:31 PM
