Old 05-31-2006, 05:37 AM   #151
rmdhawaii's Avatar
Don't you just hate it when you've been home for 45 minutes and then someone tells you that the UPS guy was here just before you came home? In any case, the engine showed up on my doorstep about a day earlier than expected. As you can imagine, I was pretty excited to open the box and check it out.
The engine came with the glow plug pre-installed, the cone collet and a silicone exhaust gasket. The carburetor, exhaust and fuel inlet dust covers are a nice touch. When you pull on the ball link connected to the throttle and release it, the throttle moves back to it's default position. There is approximately 0.5mm of crankshaft play and it can't be turned over by hand.
About the only thing that surprised me, was the "less than perfect" coating on the carburetor. Since the engine was well packed, I'm assuming that something happened on the assembly line once the coating was applied. This definitely got past any type of quality control that may have been in place. Just to make note of it, in the photos that I've seen, there is no metal exposed at all. This flaw is disappointing, but its not going to stop me from using the engine. It does however, put me on the alert for other things that might have been missed.
Didn't have time for much else today. More to come.
Team Orion CRF Wasp Rev X-Dyno results-wr0.jpg   Team Orion CRF Wasp Rev X-Dyno results-wr01.jpg   Team Orion CRF Wasp Rev X-Dyno results-wr02.jpg   Team Orion CRF Wasp Rev X-Dyno results-wr03.jpg
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 05-31-2006, 05:50 AM   #152
GrandeGixxer's Avatar
Trader Rating: 15 (100%+)
What hobby shop did you guys get the motor from? I haven't seen them online anywhere yet? Also, who has the best prices?
Joe Cude
Mugen MBX-7R Mugen MTX-6R Mugen MTC-1 Mugen MRX-6 Mugen MST-1 Tamiya Euro Truck
GrandeGixxer is offline   Reply With Quote
Old 05-31-2006, 05:52 AM   #153
rmdhawaii's Avatar
You can contact Ultimate Hobbies and obtain it via mail order. It is not posted at their Web site. Engine was $265. They may not have any left. No extra plugs as of last week Friday.
Old 05-31-2006, 09:04 AM   #154
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
I live on the East Coast. My motor will probably be here thursday or so.
Artificial-I is offline   Reply With Quote
Old 05-31-2006, 10:14 AM   #155
rmdhawaii's Avatar
I paid $32.50 for 2nd day air to be sure I had an engine to race with this weekend.
Old 05-31-2006, 10:22 AM   #156
Cool, thanks.
Joe Cude
Old 05-31-2006, 02:54 PM   #157
jag
jag's Avatar
Sweet!
Now get to work.
jag is offline   Reply With Quote
Old 05-31-2006, 04:33 PM   #158
Jammin'Trey's Avatar
Send a message via ICQ to Jammin'Trey
HAha Break it in !!!
Jammin'Trey is offline   Reply With Quote
Old 05-31-2006, 05:33 PM   #159
rmdhawaii's Avatar
Not going to happen until Sunday. That's why I knew Artificial-I was going to break his in first.
Old 05-31-2006, 06:29 PM   #160
RC Mushroom has them in stock, they want $305 though.
Joe Cude
Old 05-31-2006, 06:33 PM   #161
Moderator
Dont forget the overly exspensive shipping and 30 day waits from those hk shops.
Old 06-01-2006, 11:15 AM   #162
Josh Cyrul's Avatar
The marking on the anodizing is standard - that's where they machine the burr off the back of the carb and machine the barrel for the carb - All of the engines carbs that I have look exactly the same. It's to ensure that the barrel/spray bar alighnment is perfect and if you crank down on the spray bar, the back of the carb doesn't mess up the alighnment of the spray bar.....
Destiny, Ko Propo, Hobby Wing, Ulti Racing Tires, Protoform, Xenon Racing, Pivothead, Vizon, TQ Wire & Hella Graphics
Josh Cyrul is offline   Reply With Quote
Old 06-01-2006, 11:28 AM   #163
Josh Cyrul's Avatar
As far as oil content - All the testing I did at CRF was with their "David Spashett Peak Fuel" that was 8-9% oil. I haven't had a chance to test with lower percentages yet. When I run here, I will be running Tornado fuel - I think that's around 8-9%.
Plugs - We used the 7 Orion plugs. Again, I haven't had a lot of time to test how the Orion plugs compare to other mfg's and the temp operating range that they should be used in. Once I test a bit more and sort it out I'll post some info. I would just start with the 7 and go from there.
rmd - As far as the carb setting - The bottom end and idle we barley adjusted from stock. Maybe a maximum of 2 hours in on the bottom and out on the idle. Top end was leaned out about 3-5 hours on all the engines I tested with.
To check the durability of the engine, I cooked one!!! I got it soooo hot that it changed the color of the anodizing that is used on the head!!! That's been the engine I've been showing everyone here with the amount of compression it has!!!! It was around 320F that run!! Richened it back up and it's still running awesome with great compression. I'll use that motor to test pipes and plugs over the next few days and I'll probably start practice with it at the Nats.
Old 06-01-2006, 11:32 AM   #164
Cool, Sounds like a very durable motor! I really want one for where I race.....
Old 06-01-2006, 12:08 PM   #165
rmdhawaii's Avatar
Josh:
Thanks for the info on the anodization and carb settings! The carb settings really give me a jump start for this weekend.
Since there were no other CRF plugs available at time of purchase, I'll just be using the 6 that comes with the engine. I'm hopeful that it will last the 12-14 thanks it will be going through on Sunday.
The pipe of choice for me is the Skyline Racing Development V12 Plus. It gave my OS TZ 3-Port a lot of low-to-mid range punch and that's what I really need for the track that we run on. We'll see how it performs with the Rev. I'm looking forward to your manifold/pipe testing results - in particular, how does the high torque combo compares to the torque/speed combo.
Team Orion Wasp REV Nicolas Onroad Nitro Engine Zone 183 10-05-2006 09:04 AM
team orion wasp rev MAVICXXX Malaysian R/C Racers 31 09-19-2006 09:18 PM
Team Orion - Wasp!! BundyMan Onroad Nitro Engine Zone 1 03-03-2006 03:10 AM
Orion Element 19t Dyno results rinkrat99 Electric On-Road 7 10-09-2005 07:29 PM
Team Orion Wasp .12 HaLo_UsMc R/C Items: For Sale/Trade 6 03-16-2005 07:31 PM
