Old 06-14-2010, 02:17 AM   #1516
pistonhead's Avatar
Hi, i have the X312T and i want to find out what clutch shoe to use.
i have a team magic G4JS.
i have the 1.8mm yellow hard spring in the clutch.
0.5mm clutch gap.
1.2mm preload.
wat shoe do i use?
(Brown, super hard)
(Red, harder)
(White, high grip)
at the moment i have a soft black shoe and it slips a bit.
___________________
Serpent 747
Flash .12 3 tuned
Fataba 3PMX 2.4GHz
Ulti Tyres
pistonhead is offline   Reply With Quote
Old 06-14-2010, 03:52 AM   #1517
gtrmx's Avatar
use the white one...
I've had TM cars for years now and I even used the KFactory clutch in my RRR and loved it!!
gtrmx is offline   Reply With Quote
Old 06-15-2010, 11:03 PM   #1518
pistonhead's Avatar
thanks,
is there a spacific clutch gap to use with this engine (X312T) i understand that the clutch should engage around the 28Krpm range to get the power out of it.
so is .5mm clutch gap too small ?
could someone shed some light.
thanks.
___________________
Serpent 747
Flash .12 3 tuned
Fataba 3PMX 2.4GHz
Ulti Tyres
Old 06-16-2010, 05:31 PM   #1519
.5 is fine just adjust the spring to feel to get it to engage when it feels good when its right youll know it
Capricorn LAB C-01 / RBtj 10 / Spectrum DX3
Roadrash730 is offline   Reply With Quote
Old 06-16-2010, 08:34 PM   #1520
pistonhead's Avatar
thanks man.
___________________
Serpent 747
Flash .12 3 tuned
Fataba 3PMX 2.4GHz
Ulti Tyres
Old 06-16-2010, 09:22 PM   #1521
np i just looked at my post and what i said kinda confused me
any way set your gaps as per and run the car if it feels like its engaging to soon u only need to tighten the spring up a couple hours at a time untill it jumps off the line like something just scared the crap out of it
Old 06-28-2010, 01:25 AM   #1522
warnos's Avatar
Default Wasp Rev .12
Just got a Orion Wasp Rev CRF ORI80000.. the motor came with two spare carbs with the HSN and inserts..
I am not sure if the motor I have already has the upgraded carb on it or if the two carbs I got with the motor are the upgraded carbs.. The carb insert on the carb on motor is shaped straight on the sides like a cylinder and tapers down at the bottom.. the other two inserts I have are more like a cone shapped insert..
Which of these is these inserts that gives better bottom end and easier tuning.. and how do I tell which carb is the upgraded carb...
Either way the motor has a more power then I need just wanna make sure I am getting as much down low as I can get..
Cheers
TCX Smokem / F104 wgp
Major Sponsor : Visa Card
TEAM SMA - www.smaracing.org
warnos is offline   Reply With Quote
Old 06-28-2010, 02:53 AM   #1523
GREGORY!'s Avatar
Cheers
the update carb is that with the cone insert and the middle needle more unscrew out.also it must be bigger in bore.just a little.check it and tell us.
" kyosho rrr wc-team orion crf "
" serpent 966-mega zx21 EM "
" mugen mbx6-picco p7r evo 2 "
GREGORY! is offline   Reply With Quote
Old 06-28-2010, 03:57 AM   #1524
warnos's Avatar
The carbs I have to compare to are like the upgrade kit. http://www.teamorion.com/news/ca40/newsid/141 it doesn't have the middle screw installed its just the body needle holder and the insert... so I gather since the carb insert on my motor is not the cone shape like the two carb kits I have it must be the old carb that is installed on my motor.. and I need to upgrade the body the needle holder and the carb body and insert. Well at least I have the parts to do it already..
Is anyone using the old carb to good effect.. it seems to be working fine.. I might just wait a while before changing everything over... or is there a real need to do it?
Cheers
Old 06-28-2010, 04:29 AM   #1525
GREGORY!'s Avatar
Cheers
like i said,the new body is saying that has a bigger bore.
the new settings can be found in the link bellow.
http://teamorion.com/FAQ/Wasp+Rev+CRF+Tuning
the new carb make a better low power.
where did you buy this engine?
Old 08-10-2010, 02:50 PM   #1526
MikaR's Avatar
hi, what are good baseline carb settings for the CRF .12 ? what are you using ?
(16% nitro)
http://modelcartuning.simplesite.com/
MikaR is offline   Reply With Quote
Old 08-31-2010, 06:31 PM   #1527
GREGORY!'s Avatar
hi mika!
a little late for the answer but i see it now!
i am at 2 turns in high needle,and 4 at the low needle.1/2 the middle.( i have the old carb with update high needle body,)
this engine runs with a novarossi 2630 and rb fuel.i think tha fuel play a big rule,because if i put the factory settings and go from there the engine makes misfires.
Old 08-31-2010, 07:32 PM   #1528
GREGORY!'s Avatar
does anyone know where can i find a rod for this engine?
ori81305.
thank you!
Old 09-01-2010, 03:00 AM   #1529
gunna do's Avatar
what plugs suit the orion 12 motors os plugs or novarossi
BLITZ BODIES,FUTABA 4PK,CAPRICORN LAB C02,ATS TYRES,CAPRICORN SQR ENGINES,PROTOFORM SRS N BODIES.
gunna do is offline   Reply With Quote
Old 09-01-2010, 04:34 AM   #1530
GREGORY!'s Avatar
sirio ones and grp that has the sape taper if i am not wrong!
Team Orion Wasp REV Nicolas Onroad Nitro Engine Zone 183 10-05-2006 09:04 AM
team orion wasp rev MAVICXXX Malaysian R/C Racers 31 09-19-2006 09:18 PM
Team Orion - Wasp!! BundyMan Onroad Nitro Engine Zone 1 03-03-2006 03:10 AM
Orion Element 19t Dyno results rinkrat99 Electric On-Road 7 10-09-2005 07:29 PM
Team Orion Wasp .12 HaLo_UsMc R/C Items: For Sale/Trade 6 03-16-2005 07:31 PM
