Old 05-12-2008, 11:51 AM   #1501
GREGORY!'s Avatar
Originally Posted by FREELANCE_RCer View Post
Looks like PICCO took the .21 size engine production from Japanese manufacturers.
These seen @ redrc.net website for off-road use.
The wait will still be a little longer for on-road for sure.
take a look here->http://www.kyosho.de/?page=shop/flyp...7e&setlang=deu
GREGORY! is offline   Reply With Quote
Old 05-31-2008, 03:00 AM   #1502
Roger's Avatar
I have an Orion CRF .12 motor. My issue is that it stutters on the low end. If I initially give it full throttle at the beginning of the power curve, it " stutters " on the low end until it clears out and is normal on the mid / high rpm range. I've tried adjusting the needles and it still does it. Any ideas on what's happening ? Thanks in advance.
http://nitrokb.netne.net/profiles/RogerSerafin.html
Roger is offline   Reply With Quote
Old 01-24-2009, 09:33 PM   #1503
GREGORY!'s Avatar
hi guys.i know that this is an old thread but i want to make a question!
i am going to replace the crank in my crf.i can find 5.5mm-6mm-6.5mm diameter crank for a good price.does any one know which is better?with the big crank timing that this engine has in mind.
have anyone try 5.5 or 6.5crank?
any help will be appreciated!
Old 01-27-2009, 03:54 AM   #1504
GREGORY!'s Avatar
no one have an answer??
nano?do you know the answer?
thanks!
Old 02-02-2009, 07:07 AM   #1505
Nano's Avatar
thanks!
With the CRF technology, bigger bore cranks do not give straight results like with standard engines. I would tell you to keep the original crank.
Nano is offline   Reply With Quote
Old 02-02-2009, 03:06 PM   #1506
GREGORY!'s Avatar
thank you nano!
for one more time you help us!
very nice!
by the way you have a pm.
Old 06-03-2009, 07:43 PM   #1507
jeremy reed's Avatar
Default settings
was wondering if anyone could tell me the factory settings for the crf 21.not the new one
Team KAMIKAZE Racing
"DONT RUN,YOU'LL ONLY DIE TIRED"
PANCAR
jeremy reed is offline   Reply With Quote
Old 06-04-2009, 12:44 AM   #1508
MikaR's Avatar
sorry I commented something that was a year old posting
http://modelcartuning.simplesite.com/
MikaR is offline   Reply With Quote
Old 06-19-2009, 04:15 AM   #1509
GREGORY!'s Avatar
hi.
does anyone have try the new clutch from orion for the rrr?#ori88691
does it use the #ORI88637 flywheel?
can i buy the bell only?
does it has the same clutch parts with the crf clutch that was coming with the crf engine set?
thanks!
Old 07-02-2009, 09:34 AM   #1510
I have a question
This dynamometro I it can buy in some place┐?
In case of being able to buy it to that I coast┐?
If I cannot buy it I can obtain the planes of dyno┐?
isidur is offline   Reply With Quote
Old 01-15-2010, 10:15 AM   #1511
GREGORY!'s Avatar
i try to find i direct pin clip for this engine.i can't find any.i have try novarossi,and grp but they are not the same.this engine need a thinner clip.can someone say if the sirio clips can be used?
thanks in advice!
Old 05-30-2010, 05:42 PM   #1512
shiston's Avatar
Hi,
I'm getting the Kyosho X312T version of this engine soon. Will be running 16% nitro fuel and looking at using the no.6 orion glow plugs. What is the head clearence of this engine from factory and what head clearence should I use with 16% nitro fuel? I'm thinking the head clearence to use is 0.1mm?
Hang around......we'll talk some more
shiston is offline   Reply With Quote
Old 05-30-2010, 09:48 PM   #1513
GREGORY!'s Avatar
yes.0.1mm.
" kyosho rrr wc-team orion crf "
" serpent 966-mega zx21 EM "
" mugen mbx6-picco p7r evo 2 "
Old 06-05-2010, 12:16 PM   #1514
Raman's Avatar
Trader Rating: 56 (100%+)
Is it me or have the parts supply for the CRF Wasp .12 completely dried up.
Since the wasp .12 is no longer available, can anyone confirm if the Alpha .12 parts will work?
Raman is offline   Reply With Quote
Old 06-05-2010, 12:49 PM   #1515
MikaR's Avatar
Raman Try bartz parts or barts partz
I bought a cranck not so long time ago.. good service
Team Orion Wasp REV Nicolas Onroad Nitro Engine Zone 183 10-05-2006 09:04 AM
team orion wasp rev MAVICXXX Malaysian R/C Racers 31 09-19-2006 09:18 PM
Team Orion - Wasp!! BundyMan Onroad Nitro Engine Zone 1 03-03-2006 03:10 AM
Orion Element 19t Dyno results rinkrat99 Electric On-Road 7 10-09-2005 07:29 PM
Team Orion Wasp .12 HaLo_UsMc R/C Items: For Sale/Trade 6 03-16-2005 07:31 PM
