Old 05-08-2006, 04:52 PM   #1
performula's Avatar
Default Removing crankshaft?
I pulled apart my RS12 and I cannot get the cranksaft out. How do I got about doing this? Everything else came apart fine.
performula is offline   Reply With Quote
Old 05-08-2006, 05:47 PM   #2
Rapid Roy's Avatar
Sometimes I have to tap on the shaft with the handle of a screwdriver to slide the crank out of the bearing.
Rapid Roy is offline   Reply With Quote
Old 05-08-2006, 06:07 PM   #3
performula's Avatar
Thank you.
Old 05-08-2006, 06:09 PM   #4
performula's Avatar
That worked great. I didn't know if there was a pin or channel/groove I was missing. Thanks again.
Old 05-08-2006, 06:20 PM   #5
teammpp's Avatar
Lucky you. I went to remove the crankshaft on my RS12 at the beginning of lastyear. Tapping didnt work.
Took 90psi on a pneumatic press to remove it.
teammpp is offline   Reply With Quote
Old 05-08-2006, 07:07 PM   #6
performula's Avatar
Good Lord!
Old 05-09-2006, 12:41 PM   #7
E.T.'s Avatar
I thought you have to heat it up on the stove a little, if the shaft refuse to come out. Of course the cub. must be remove before this process. Some engine is installed with a rubber seal on the front bearings, so be careful.
Forcing it out may damage the shaft & bearings...
E.T. is offline   Reply With Quote
Removing epoxy ramp on crankshaft... Poppin Fresh Nitro Off-Road 24 09-01-2008 05:49 PM
HPI F4.1 Crankshaft marvs777 R/C Items: Wanted to Buy 0 12-22-2007 02:29 AM
JP FX3 CRANKSHAFT rchopeless Australia Wanted to Buy 0 01-01-2007 03:47 PM
rb x12 SG crankshaft cmain R/C Items: Wanted to Buy 0 06-24-2006 08:46 AM
crankshaft haowee Singapore R/C Racers 0 09-26-2005 08:16 AM
