Old 05-06-2006, 10:33 PM   #1
Default Seeking carb O-ring for NovaMega KHM
Greetings, all
I am desparately seeking an O-ring for my NovaMega SX21KHM Evo6 engine.
I am not looking for the 2765 O-ring that fits over the end of the carb.
The O-ring I need is the one that goes inside the crankcase, deep within the case at the bottom of the cavity where the carb slides into. The stock O-ring is frayed and cut a bit. I took it out to examine it, and found that after I took it out it has also swelled up enormously so that I cannot put it back into its groove now.
The approximate dimensions are: 1.6mm thick, and slightly larger than 15mm outer diameter. I believe that the outer diameter may be slightly larger.
I cannot find a parts list that shows this O-ring.
(I have attached a picture.)
Can anyone help me out, please?
GlennCauley is offline   Reply With Quote
Old 05-06-2006, 11:45 PM   #2
onnetz's Avatar
as a last resort you could always go this route....
http://www.oringsusa.com/
onnetz is offline   Reply With Quote
Old 05-07-2006, 12:03 AM   #3
rcfoolz's Avatar
Trader Rating: 22 (100%+)
Send a message via Yahoo to rcfoolz
Novarossi part number 14002
Am I going back racing?...Hmmm.. Not anytime soon... But soon enough.
rcfoolz is offline   Reply With Quote
Old 05-07-2006, 04:07 AM   #4
Default Much appreciated!
Thank you thank you thank you !!!!!
Glenn
NovaMega sx 21 Carb Settings cadguy Nitro On-Road 4 08-04-2007 07:10 PM
Desperately seeking RB X15 Carb golfinglenn R/C Items: Wanted to Buy 2 01-07-2007 10:46 PM
WTB 11L ROTARY CARB FOR .18TZ, HAVE NEW SLIDE CARB TO TRADE? SHAGGS R/C Items: Wanted to Buy 0 12-01-2006 03:34 PM
Looking for Novamega SX .21 carb seajj2 R/C Items: Wanted to Buy 2 09-18-2006 04:07 PM
Venturis for NovaMega Carb GlennCauley R/C Items: Wanted to Buy 0 09-01-2005 09:42 AM
