Help on .18 TZ Shimming ...
Guys,
Im ending the TZ break inn on my TNX PRO MT and have this question ... I will use the TZ mainly with 30% nitro fuel and 0mts to 1.500mts from sea level cities. The TZ comes with 2 shims on the button head, one with more with than the other : 1.- Anyone knows the measures of the stock TZ shims ?. 2.- For 30% nitro and the cities i usually will race i was thinking on taking off the thiner shim and replace it with the stock FS-18 (OS based) tamiya engine shim ... do you think its a good idea in order to end with a good relation of temperature and fuel comsumption on the engine ? If not on the point number 2, which othe shim combination you think its good for my sea-level conditions ? thanks a lot for your help ... |
