-   Onroad Nitro Engine Zone (https://www.rctech.net/forum/onroad-nitro-engine-zone-71/)
-   -   Mephisto vs Mito9 (https://www.rctech.net/forum/onroad-nitro-engine-zone/1054323-mephisto-vs-mito9.html)
BigC2007 11-20-2019 09:03 AM
Mephisto vs Mito9
Hey guys for those that have had both which one would be a better choice ? I know the Mephisto is newer but I still see a lot of Mito running still.
gwilli2001us 11-20-2019 12:00 PM
I've run both, the Mephisto is an Xtra long stroke and does have a little more bottom end torque which is good if the track surface has good bite.
and it is thirsty, not the best fuel mileage.
The Mito is a little friendlier on the throttle and has good mid-range and top end. I also really like the Mito 35 WC. Sorta feels in-between both. Keep in mind, I ran all of the above stock out of the box, did no mods. All were ran on 25% nitro, 6% castor, 3% synthetic oil. Nova conical medium header, Nova 2015 pipe w/stock cone hole sizing. Head clearance was .07mm
BigC2007 11-22-2019 06:34 AM
Thanks Glen for the information
BigC2007 11-22-2019 06:36 AM
Hey Glen is the Mito 35 WC factory Modded ?
gwilli2001us 11-22-2019 06:29 PM
No, all were stock. There is a lot you can do with the Mito, Hopefully, I can finish up a modded one for the TFT at SCS
