OS T1203 .12
#16
#17
ok will check it out. Roelof told me about your site
give him some credit!
#19
Tuning is not a lot different, as long as you do not run the engine too lean on the main-needle, you should be OK.
#20
To be honest we have very little choice nowadays with the demise of Novarossi our only realistic option now are O.S. based engines.
#21
#22
Anyway lets see - rumours are rumours after all.
#23
Thats cool. Let's see what comes out the mill. Glad you can get some T1203 stuff as we can't here and was told production of T1203 had ceased until November where it would be replaced with the T1204. Perhaps this is the last production that you might be a part of and O.S. aren't accepting new orders?
#24
I have been pretty fortunate here in the States. I compete in a regional series,(MidWest Series) where only one race was canceled. I was lucky enough to travel out of town to some other races that were C19 friendly with protocols. I would like to get a new engine or two soon as the winter racing in Florida will be starting up in November. Just researching my options.
#25
#26
T1204 available early december 2020
#27
Didnt wanna say told ya so All good! Gonna be a great engine for sure.
https://www.redrc.net/2020/09/os-speed-t1204-12-engine/
#28
#29
I was fortunate enough to run the 2020 Miami Grand Prix recently. I broke in a 1203 combo and it was a great experience. The engine ran as good as anything I've raced in the past and held a great tune even with changing weather conditions. All sounds great, right? The quals were 4 minutes and I know there wasn't enough fuel left to run the usual 5 minutes at my home track..(Toledo O). I asked around and was told a opit will be needed to run a 5 minute qual. I'm considering adding a .01 shim and maybe a smaller restrictor. I ran it at or just below 250* F. Any advise would be appreciated.
#30
The Novarossi 2660 pipe with the short manifold works well on the OS and does increase its runtime over the OS pipes. I'll miss the Novarossis as those will run 5 minute qualis all day all night without much hastle.
You'll also need to drive super smooth and consistently as that also helps massively in making 5 minutes. You'll also need to run fairly lean which an OS can take and so fuel choice is also critical - I'd highly recommend Energy for this as the oil package is particularly good and you can run quite lean with this fuel over some of its competitors.
Alternatively some of the tuners out there can modify engines to help with runtime as well so worth talking to some of them to see what's out there.
