OS R21 .21 1/8 On-road Motor
#61
Hi. I just got myself a brand new never run OS speed R21 Eurospec. The instruction sheet says its set for 25% nitro. Is anything required (Head shim change perhaps?) to run with 16% nitro?
#62
On short tracks(and you want to squeeze all out of your engine) you can try without the copper shim(0.1mm) but in general I suggest you leave it as is.
#63
New R2104
#65
#66
When would you run 0.2mm gasket?
#67
#69
#71
#73
Not used in a GT, do not own one but some club members do run it in an onroad, and it is a decent enging.
I did measure the timings and it is somewhere in between an offroad and an onroad so I think it will meet up with the needs of a GT but there is one thing, you probably want a larger head for a better cooling.
#74
Scratch that!
