Go Back  R/C Tech Forums > General Forums > Nitro On-Road > Onroad Nitro Engine Zone
OS R21 .21 1/8 On-road Motor >
Like Tree14Likes
Old 03-08-2019, 05:29 AM
  #46
1/8 IC Fan's Avatar
Trader Rating: 96 (100%+)
Originally Posted by invrtd View Post
R21 Euro and R2103 based on part numbers look like the same motor. Was looking at a EURO spec to run 16% just in case I decide to run worlds.
Yeah thats what Rody said too, same more just no DLC and Black case coloring. Still waiting on mine to arrive.
1/8 IC Fan is offline
Old 03-08-2019, 07:16 AM
  #47
R/C Tech Elite Member
VS_Rody's Avatar
Piston/liner and crankshaft are not the same, check the partnumbers.
Rick Vessell likes this.
VS_Rody is offline
Old 03-08-2019, 10:18 PM
  #48
Michael_T's Avatar
Trader Rating: 52 (100%+)
The crankshaft and cylinder / piston port timing have changed with the “Euro” spec. In a nutshell, these changes theoretically are supposed to give it abit more top end to suit the large European tracks (hence its name).
Michael_T is offline
Old 03-09-2019, 01:22 AM
  #49
Roelof's Avatar
In other words, it will fit but it will change the performance a tiny bit?
Roelof is offline
Old 03-09-2019, 02:38 AM
  #50
VS_Rody's Avatar
Correct, Euro spec a little more top speed.
VS_Rody is offline
Old 03-09-2019, 03:18 PM
  #51
I have 2 R2103, from Japan, and Im not sure if they have the 25% combustion chamber or the 16%.
nitrodude is offline
Old 03-09-2019, 06:55 PM
  #52
1/8 IC Fan's Avatar
https://www.osengines.com/engines-ca...020/index.html
Per their site it is setup to be compatible with 16%, although the site states to break in with 20%.
Old 03-13-2019, 06:31 AM
  #53
Jason Smith's Avatar
Would I be able to rebuild my 2103 with the 2103 euro p/s/r? Or would the 2103 crank cause issues with timing?
Jason Smith is offline
Old 03-13-2019, 07:30 AM
  #54
VS_Rody's Avatar
Hi Jason,
Yes, you can, parts are compatible and no issues with the timing.
In fact the timing of the EuroSpec is the same as the 2103, it has some small mods on the liner and a lighter piston.
Rick Vessell and GREGORY! like this.
VS_Rody is offline
Old 06-11-2019, 05:29 AM
  #55
Pooh2's Avatar
Hello Rody. I have a question. I see a lot of the factory drivers still using the 2103 over the Euro. Is there a reason for that you know of?
Pooh2 is offline
Old 06-11-2019, 06:07 AM
  #56
VS_Rody's Avatar
Technically there is very little difference between the engines. Also maybe because the engines are very reliable and the factory is not giving out so many engines, they stick with what they have available.
Just a guess though
Rick Vessell, davidl and Pooh2 like this.
VS_Rody is offline
Old 08-28-2019, 12:59 PM
  #57
jasoncsc's Avatar
Hi, I just got myself 2 sets of R21 Euro Spec engine combos. Do I need to put shims on them if I run them on 25% nitro fuel? If so, which shim I should put on? Thanks
jasoncsc is offline
Old 08-29-2019, 12:21 AM
  #58
VS_Rody's Avatar
You can use them out of the box with 25% nitro.
VS_Rody is offline
Old 08-29-2019, 12:31 AM
  #59
jasoncsc's Avatar
Thank you Rody!
VS_Rody likes this.
jasoncsc is offline
Old 08-29-2019, 07:50 AM
  #60
Ive ran the R2103 on 25 and 16, and IMO it runs better on 16.
