Like Tree10Likes
OS R21 .21 1/8 On-road Motor
Old 10-09-2018, 05:47 AM
  #16
R/C Tech Elite Member
VS_Rody's Avatar
Originally Posted by ralphierace13 View Post
rody the 2103 have different part numbers from the 2101 and 2103, for the crankshaft and piston and sleeve. do you know that the diff is ?
I tried once using the crank from a 2103 in the 2101 and had the same head shims for the stock 2101 .03 when I went to start it the piston from the 2101 was hitting the button I had to add another .03 shims
The crankshaft of the R2101 and R2102 are the same. The R2103 has a different timing(more closed).
The Sleeve of the R2101 and R2102 are the same. The R2103 has a different shape on the exhaust.
You must have done something different because for me the stroke of all these engines are the same. Crankcase has the same measures and so have the sleeves.
VS_Rody is offline
Old 10-09-2018, 11:18 AM
  #17
What is the difference between the O.S. SPEED R21 EURO SPEC and the O.S. R21 ?
fergraz is offline
Old 10-09-2018, 11:38 AM
  #18
1/8 IC Fan's Avatar
Trader Rating: 91 (100%+)
I think the motor you are talking about is the same as the Shimo motor, no longer available. OS R21 is basically a base Speed motor, without all the add ons.
1/8 IC Fan is offline
Old 10-09-2018, 12:42 PM
  #19
VS_Rody's Avatar
The EURO spec looks interesting on paper. New sleeve(design) and piston(lighter), this in combination with the R2102 crankshaft should be a good engine for larger tracks where more topspeed is needed.
VS_Rody is offline
Old 10-09-2018, 02:23 PM
  #20
Thanks! The R21 EURO SPEC is 5 ports or 7?
fergraz is offline
Old 10-09-2018, 03:18 PM
  #21
ralphierace13's Avatar
thanks rody, rody if you get a chance I don't want to bother you but if you get a moment can u measure the pin on the 2101 crank and 2103 like measure the pin from the out edge to where it sits and from the inner edge and see if you get two different measuerments because I did I just don't remember what were the measurements is was long ago and I don't have both cranks any more thanks so much..
ralphierace13 is offline
Old 10-09-2018, 07:24 PM
  #22
VS_Rody's Avatar
Better wait until it has been released, then I can confirm but for me it will be a 7-port.
VS_Rody is offline
Old 10-09-2018, 07:40 PM
  #23
VS_Rody's Avatar
No different measures on my side.
If you find different measures then maybe you have an 21XZ crankshaft in one of your engines...
The 21XZ has a stroke of 16.8mm while the R21 engine has a stroke of 17.2mm
VS_Rody is offline
Old 11-11-2018, 11:56 AM
  #24
hi rody any more you can tell us about the euro spec now you have them in
stock and have a rody tuned version,is this a 2102 with a new piston and
liner set for more topend or a new crank as well.
rick oxley is offline
Old 11-12-2018, 02:19 AM
  #25
VS_Rody's Avatar
Hi Rick,
The crankshaft is the same as an 2102 but with the new piston/sleeve, this combination will get you more top-speed but also more fuel consumption.
The new piston/sleeve/conrod is available here: Kit Piston/Liner/Conrod SPEED R21 EURO SPEC
VS_Rody is offline
Old 11-12-2018, 02:54 AM
  #26
Roelof's Avatar
130 for a P/S/R set ???? Wow!
Roelof is online now
Old 11-12-2018, 04:16 AM
  #27
VS_Rody's Avatar
Good or bad?
VS_Rody is offline
Old 11-12-2018, 05:36 AM
  #28
1/8 IC Fan's Avatar
I think thats good, actually. I have seen sets in Germany for Picco and Nova going for 160-180 Euro.
VS_Rody likes this.
Old 11-12-2018, 05:37 AM
  #29
Roelof's Avatar
Good!
OK it is ex VAT but even then those are reasonable prices, Like a top engine P/S set for just 125 euro.... Even a Novarossi cheap Basic P/S set like a Brave does not come close to it regarding some sites, funny thing is that a 35+ P/S set is alsmost the price of a complete 35+ engine..
Old 11-16-2018, 04:45 AM
  #30
invrtd's Avatar
Trader Rating: 24 (100%+)
Blue head R21? How is this motor in a GP car? I am coming from Offroad and GT background. So I do some onroad racing. Just got a shepherd V8 and was looking for a good first motor. I have a Keep On new in box I could probably sell and get the R21. I run all OS in my offroad and GT. I use the old blue head xz-b in GT with great results. Not sure if the extra money for a new r2103 will benefit me right now. I think the R21 will do fine but curious on performance difference between R2101-2103.
invrtd is offline
