Pinch question
Ok so here is my question, i race 1/10th turing cars and know about how much pinch my motors should have after a gallon or so. Im getting into 1/8th scale off road, but my .21 a novarossi P5X after a gallon feels like it has a lot less pinch that my .12's have in the past.
Thanks Lee |
An engine is not fully broke in until all noticable pinch is gone. If you are talking about compression that is a different thing. My P5X did'nt break in untill is hit the 1 1/2 gallon mark and now I can' t control the stupid thing! :)
regardless the pistons;sleeve fitting, if it's tight or loose..........
if your engine runs fast and has a consistent idle and if there's no play on conrod bushings, crankshaft pin and bearings............don't worry about pinch........ |
Thanks for the info. I was just at the track and this motor is getting faster and faster. Im usually an onroad guy, i got a buggy because we have a good track here, just wanted to make sure i wasnt messing up my new motor.
| All times are GMT -7. It is currently 01:08 PM. |
