Go Back   R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Like Tree3Likes
  • 2 Post By PerryCodes
  • 1 Post By houston
Old 07-23-2017, 09:25 AM   #1
Default Front Bearing: Will Ceramic Make a Difference?
So... I'm replacing the bearings on an engine. There is a company that offers a ceramic bearing for the front, but only steel for the rear. Would there even be much of a benefit to replace just the front bearing with a ceramic one? Or should they both be ceramic to realize any sort of benefit?
Thanks!
Last edited by PerryCodes; 07-24-2017 at 10:51 AM. Reason: Changing title to match question
PerryCodes is offline   Reply With Quote
Old 07-23-2017, 07:24 PM   #2
grizz1's Avatar
Thanks!
Ceramics don't like dust and dirt, so unless your running something like the Buku bearing caps on your crankcase go for a steel front bearing. Starter box loading also isn't favorable with front ceramics due to making the balls "skid" instead of roll on cold starts.
Main ceramics give a small performance increase, so worthwhile doing if your a serious racer. For play, just go steel front and rear.
grizz1 is offline   Reply With Quote
Old 07-24-2017, 03:15 AM   #3
Roelof's Avatar
Send a message via ICQ to Roelof
Have you ever used the search function, this question pops up several times a month....
Yes, on paper ceramics are better, in reality the difference will not be noticed by many racers. Yes, when an original steel bearing did go bad and you place a ceramic you will notice an improvement but the same improvement will be noticed as well with a new steel bearing because the worn one did give performance loss.
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Old 07-24-2017, 09:11 AM   #4
No... Search Function? What is that? Could you please explain it to me?
Of course I have. And "several times a month" is quite the overstatement... Not counting my topic, there have been exactly ELEVEN topics with the word "ceramic" in the title since May of 2011. It may seem like it's brought up regularly... But no... it's not.
Besides... my question isn't just the typical "Which is better - Ceramic or Steel?" that comes up "regularly" ... Perhaps I chose a poor title. (I tried changing it, but this forum framework doesn't change the entire thread title when the first post is changed like phpBB does ). I'm asking whether using ceramic in the just the front would offer any benefits. I'm very glad I did ask the question, because as grizz1 points out... there is a scenario that I didn't know about - nor had I read about in the other 11 topics:
And for those readers who have never used the search function, but interested in the opposite scenario - ceramic in the main and steel in the front - it HAS already been discussed: http://www.rctech.net/forum/offroad-...r-bearing.html
Warm Regards ~ Jason
slodsm and offroad dude like this.
Old 07-25-2017, 05:44 PM   #5
houston's Avatar
Trader Rating: 91 (100%+)
honestly the quality of the bearing and clearances it is built to has more of the benefit then just ceramic or steel .... novarossi literally makes/uses some of the best bearings in the industry for micromotors ..
novarossi steel rear main bearing is better than most manufacturers ceramic rear main bearings ...
happy motorin'
am likes this.
TEAM FUSION X ENGINES /RC-OMG USA/ TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Team Associated RC10 B5m Mid-Motor Thread RCBuddha Electric Off-Road 21186 Yesterday 03:06 PM
Team Associated SC5M Thread 3srcracing Electric Off-Road 2705 Yesterday 05:37 AM
NEW OS 21 XZ-B and Speed XZ-B Marcus Falconie Offroad Nitro Engine Forum 5225 07-11-2016 06:24 PM
