RB con rod
Old 06-09-2017, 05:26 AM
Default RB con rod
Can anyone tell me if there is a novarosi equivalent to the RB bxr ls con-rod no 01122-c (std rb 21 )
noddy2 is offline
Old 06-09-2017, 06:40 AM
Roelof's Avatar
It seems the rod from the Adam Drake is the same rod.
Roelof is offline
Old 06-09-2017, 10:55 AM
22Racer's Avatar
Trader Rating: 67 (100%+)
Rb normally have just a .002" or so larger crank pin size. There were some that had the std. Nova size in the last few years though. Roelof is correct, I have worked on Drake engines and they also have the larger crank pin like a Rb so that rod whould work great. I have also reamed out a used Nova rod to fit in a pinch.
Rex
22Racer is offline
Old 06-10-2017, 02:35 AM
Rex
Thanks very much guys, great news ,will follow up! Great tip about the crank pin size also.
noddy2 is offline
Old 06-10-2017, 03:01 AM
Roelof's Avatar
That I have done once:
Roelof is offline
