Go Back   R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Like Tree4Likes
  • 3 Post By Winner's Circle
  • 1 Post By hairymuffin
Old 04-12-2017, 01:48 PM   #1
Default Regular flameouts during refueling
Hi everyone,
I'm having regular problems with flaming out during refueling with a fuelgun. I've been trying to solve this issue for so long without success that I thought it's about time to ask some engine guru's.
Observations:
The engine seems to flame out because of lack of fuel - I'm sure that it's not because of too rich bottom. So I thought - probably too lean bottom... Last race I set it pretty safe - that is: when the engine was idling on the box it would build up and bog after applying full throttle after several seconds. Still the engine died 2 times in the main final (both times during refuelling).
What I tried:
- leaner bottom end
- richer bottom end
- new glow plug
- fresh fuel
- new fuel tubes
- sealing backplate of the engine
- keeping the engine at idle while refueling
- reving the engine when refueling (I know it's not good - I did it just to try)
My setup:
- Mugen MBX7
- Alpha Lutz WE + 2107 pipe + 7mm venturi
- Rapicon fuel
- Losi fuel gun
I'll appreciate any ideas
Donat is offline   Reply With Quote
Old 04-12-2017, 02:55 PM   #2
kgombe's Avatar
seen this happen with a local racer numerous times no matter what car or engine... but he now uses a fuel bottle and that went away...
it's usually a fat bottom, or you just coming in to late for fuel?
Kijana Crichton
kgombe is offline   Reply With Quote
Old 04-12-2017, 03:04 PM   #3
Winner's Circle's Avatar
I think it is a fat bottom. Try a hot plug and see if that helps.
Lee
Lee Muse
[email protected]
Kyosho ST-RR, Kyosho MP9, Murnan Modified Engines
Winner's Circle is offline   Reply With Quote
Old 04-12-2017, 03:07 PM   #4
That's true, it doesn't seem to happen as often with fuel bottle... I would however want to find a solution as fuel gun is much quicker.
I'm pitting usually at 7:30 with fuel left for another 1min or more so no last call refuelling for sure.
Lee
I know that it's pretty common problem but it really doesn't seem like the engine is dying because of too much fuel but rather too little. I'll lean it out a bit to see as I'm still on the safe side I'd say. Maybe I'm misjudging it...
As for the glow plug I'm using Picco P5TH which is already a hot plug.
Old 04-12-2017, 04:38 PM   #5
timjs's Avatar
Not wanting to idle is one of the first signs of low compression, could that be a possibility in your case?
timjs is offline   Reply With Quote
Old 04-12-2017, 05:33 PM   #6
That shouldn't be a problem. The engine still has very good compression, it's about 10L old and the problem was occuring earlier as well. I don't have a problem with idling in general, just when the car is being refueled with a gun.
I asked Ryan Lutz and actually he might be spot on! I asked what is the most common reason of engine dying during refueling with a gun (apart from too rich bottom end).
Ryan's response:
"Fuel guy blocking fuel tank completely with gun.
Hold gun at slight angle to allow air beside it."
That really might be the reason as the Losi gun seals the hole in Mugen tank very tight. I will test that next time and will let you know if it solved the problem!
Old 04-12-2017, 06:49 PM   #7
hairymuffin's Avatar
Trader Rating: 96 (100%+)
It's the fuel gun closing the top of the tank, lutz pointed this out years ago to my son. He said mugen did this more often than other brands. He said to not put the gun all the way in the tank,(not touching the tank)voila no more flameouts during fueling. Also helps to rev the engine before you set the the car down
Donat likes this.
hairymuffin is offline   Reply With Quote
Old 04-12-2017, 06:51 PM   #8
Ryan's response:
I didn't read all your post before I posted mine lol...
Old 04-12-2017, 07:04 PM   #9
I would not even think of that, I would be like damn rich lsn
TLR 8IGHT Nitro Buggy RTR converted to 3.0
Evoking1230 is offline   Reply With Quote
Old 04-12-2017, 07:15 PM   #10
Lutz will help you out no matter what brand you run
Old 04-25-2017, 08:51 AM   #11
bypass911's Avatar
Trader Rating: 14 (100%+)
When you come into pit, clean it out with full throttle a couple times before fueling.
Sweep Racing
bypass911 is offline   Reply With Quote
Old 04-26-2017, 08:12 AM   #12
savagesam's Avatar
Seen this many times, crack the top of the guns lid open a fraction and the issue goes away, just work out the best way to keep the lid open a fraction, piece of fuel tube
savagesam is offline   Reply With Quote
