Some engine questions
Hello everyone i have a losi 3.4 that i just bought and i am looking for a very small flywheel for it and the one that fits my size requirements is Hot Racing SAV1100S3 now my question is how do you know if it will fit my losi or are flywheels universal, my apologies if this is a noob question i dont play much with nitro
Use a smaller collet. If it lines up with the spur then don't worry about it.
A large space is no problem if the rest of the clutch can be mounted with no issues.
Otherwise you can shorten the collet by grinding a bit off.
Hi Roelof, I have that same issue with my Brand New OS XZB 21 ver 2 Blue head. It is mounted in my HONG NOR X-3 sabre. I didn't get a collet with my Flywheel when I received it from the seller. The Flywheel lines up with the back end of the clutch bell. It seems to turn over easy.I haven't started the engine yet and I might just pull it out and take a little off with a Dremel tool and a cut of wheel. thanks Michael
Hong nor x3 sabre rtr 1/8 buggy nitro question
Can anyone help me with their idea of best nitro percentage and castor percentage and plug. I have the force .28 engineering. Currently was running 20% and 9%castor with an ornament hot plug b4. Wondering if anyone had suggestions for me. I don't run track but people around town and I like to spank them. B4 hot plug ofna, beyond 20$9%. 3.25 hours out on Jan and flush land with 1mm to. 06/7 my on idle screw. I was told to try 4.5 hours on hand and 2.5 on lunch, but want to know best fuel to use and plug without overheating. Please some help me out with some of your own thoughts. Thanks, JT
BTW how hot the engine runs is mostly a function of how it is tuned, not what fuel and plug are used.
