O.S. SPEED .21 XZ-B SPEC. III
#107
I have ran many OS engines with several different pipes.
The 2090 will defiantly allow more top end
The 2060 is more of a bottom end pipe that chops the top off a little.
Now both of these are very header dependent. But if you use the same OS 70mm header on both pipes that's what I have felt.
This is all on the track of course.
But bolt them up and see for yourself.
#108
Anyone that trys this give feedback plz, as well what meathod of break in?
#109
Heat cycle method
1. Heat engine to 220+ idle 10 mins
2. Let cool usually about an hour
3. Repeat 1&2 3-5x
4. Heat to 220+ and bump idle up to about 1/4 throttle. Let the rest of 1qt run through the engine on a hudy break in bench keeping the temp 200+ (heater and adjust hsn/ lsn) (Usually takes about 2 hrs)
5. Run another qt through in the car on the street with the head wrapped very rich keeping the temp 220+ continuously. (Takes about 1 hr)
6. Take to the track and tune to kill. Usually there's stil metal pinch so the idle needs to be a little higher than normal until that metal pinch is gone.
3. Repeat 1&2 3-5x
#110
Heat cycle method
3. Repeat 1&2 3-5x
3. Repeat 1&2 3-5x
#111
Very impressed with this engine, I ran JBRL this weekend and engine performed flawlessly (I wish I could say the same about me LOL ) also I ran the Drake engine on my buggy and that was also a very impressive performance.
I had the chance to speak with Atsushi Hara about the engine and he was very helpful answering questions about needles, temps and overall performance of this spec 3 engine....really nice humble guy
If you are looking at this Spec 3 you will be very satisfied with it.
thanks
Josh
thanks
Josh
#112
os
UgmKSj6rqivGigtlVUD0kpGr_anxIlliiYJ1_T9QGbME8OIn8m _VQLl2L9nIhyVxtG50XtONx6EQ4O-p-l28YtvX5Zhk8fv8esdaW7ZfYEbjWScHiMBEaIrs&ats=147494 0185135&rm=15769491ad807976&zw&sz=w1904-h905[/url]
#113
Os
well I wanted to post a Picture of mine but i couldn't figure it out its so nice much nicer than my current reds.
#114
what did you ask him about it? or what did he tell you?
#115
#116
#117
I havent ran the new os and wont for a few months the reds are great quality build wise, they can hold a good tune, break in is a bitch took over a gallon before it was ready and even now it runs cold around 195.
#120
Hey guys, simple questions here! Been a ninja fan send run a bo2 as my main engine and a bo1a as my practice engine and love the power with a 2060 and bottom end threw top nothing compares to my reedy/ae 2035 which I've known for awhile is a very good non os pipe. However my question is about the spec 3, when the spec 2 is talked about people say it's a fire breather very non typical os speed feel. I like that power feel from the 2035 pipe so I know I like the sound of more power especially if it runs longer. My bo2 runs out with the 2060 and has a very controlled power band. I ran this on the Vegas world's track a week after they ran the mains and it was insane bumpy so I think the power of the b02 helped me but down the strait I needed it to run longer. I run 7 mm venturi. Will I be better off with a spec 2 or 3? I want thAt extra power down low but I gotta get something that still has that power for long straits. I'm even down to get a offbrand os engine like samurai if it has what I'm looking for. So far it sounds like the b2101 is a smooth engine, spec 2 is the most power os has ever put in (totally different then normal speed mo) and spec 3 I'm confused if it's more like spec 2 or even more power?
