clutch question
clutch question
Ok I have a M2C clutch question. I am not new to this clutch. I also have never run nitro buggy before either. Gonna give it a shot. I have two engines that I plan on running in this buggy. One is a Novarossi btta box stock. I have the quick change flywheel for this engine with medium shoes aluminum flyweel. The other engine is an Top elite 5 fully modded from TNS mods. I have the steel M2C variable weight quick change flywheel with medium shoes. My question is what is a good spring setup and what is a good starting point on how many set screws to have in both these flywheels. I know the steel flywheel is gonna be heavier than the aluminum which is the reason I chose the aluminum one for the btta and the steel one for the Top
