OS or Fusion
#16
Suspended
Great,Do you know how to make review?
#17
Just an update, made it back to Vietnam with my new x5race with a filled crank and went to the new track here in Vietnam with an engine killer straight. My fusion x5r chased down and passed everything on the track, including a new Ty worlds engine and a spec II with absolutely no problems. Monty designs killer engines for sure
#18
#19
The problem I always have with nova engines are that they have no balls down low. .. But they do Last quite a bit
#22
I am not bashing novarossi at all. .. try many combos with pipes clutch etc etc and no thing worked for me ... usually I run picco, reds ... and will try the New speed
#23
With appropriate pipe / manifold and clutch setup the nova can be made to have a violent low range if thats what your after.
i used a bonito in buggy for a while and it was too much, ive since been using it in truggy and it will still snap traction at will if your throttle is too generous.
#24
I have been OS faithful for many years. Recently I have been looking for something more mostly in terms of runtime. I have ran over powered motors in my buggy before and all I saw personally was slower lap times they were a blast to drive but not desirable in my hands. I just bolted in a x3. Will see what it can do in the track...
#25
Yeah the Nova's I used never had an issue with low end torque. I ran a bonito for a couple of big meets and as mourhino said, it was too much for buggy. Its an issue with clutch/pipe/tune.
#27
Yeah, when I got to Monty's and saw all my parts I ordered your engine was in the pile. The x5r is a runner thats for sure. Have the Buku and the 2096 021 on it. Maybe a bit softer than I like on bottom so will up the screws maybe an 1/8 or 1/4 each to see. It was hella funny though they were like 20 feet out in front on the straight and I had to make the turn to get on the straight by the first corner on the straight I was side by side and by the next sweeping corner they were in my dust back about 20 feet. Many times coming out of the corner in the straight I had to let out if I was right behind them or I would give them a little love tap in the rear. Totally loving the x5r. Put my truggy out and first jump I lost a rear hinge pin.... running the m2c and one pin wasn't tapered and I didn't notice but there was also one that was shorter. No harm no foul, had my last spare but it was at home not the track. Hope to get the truggy out and see how the x7 does Might even see how my x5l does in truck with the kyosho clutch then pick the best to try the buku aluminum shoes on....
#29
Frank what up?! Hey i switched last month to Monty's engines , and i got some mileage with my extremely heavy finger .So far 0 flame outs or issues and i can go 830 in real world fear farm conditions where as with every one of my speeds or those rc concepts i was running out at 730-745. Now i am running the x5lc in both buggy and truggy . Maybe an x7 in the future for the truggy !!
#30
I could usually go 10:45-11 with the spec II
I'm testing the X3 and samurai.
+1 to Monty. He's a great asset to the RC track. He is quite fond of denatured alcohol
