Like Tree12Likes
Maxima O.S. .21 Engine
Old 12-05-2016, 06:44 AM
  #106
Super Moderator
1/8 IC Fan's Avatar
Trader Rating: 85 (100%+)
Here is a Falcon, when they modified their OS based mills, pretty sweet job with a nice transition to the outer sleeve surface. Hopefully Maxima has progressed to this point. Either way, I know we could easily fill 20+ pages in a new thread just dedicated to porting and polishing etc.
I have not seen the inside of the new RF1512P Falcon yet, but i am sure its similar.
1/8 IC Fan is offline
Old 12-05-2016, 08:39 AM
  #107
Maximo's Avatar
that is just factory done
Maximo is offline
Old 12-05-2016, 08:52 AM
  #108
Super Moderator
1/8 IC Fan's Avatar
On the VZ-b was the it not shallower, and you could see the liner coating "overspray" on the chamfer?
V-spec is what the Falcon Evo was based on
Old 12-05-2016, 11:54 AM
  #109
Maximo's Avatar
IMO it is factory done...... However it may not be...either way it has no effect on performance, the engine would behave the same way whether it was there or not...
Maximo is offline
Old 12-27-2016, 02:29 AM
  #110
Here is a place were you can buy them. https://rcpitbox.myshopify.com/search
kyosho28 is offline
Old 12-29-2016, 07:21 AM
  #111
Default Maxima O.S. 21B2R
Does anyone know... where abouts is can purchase a Maxima O.S. 21 b2r from?
WavyEnzo is offline
Old 12-29-2016, 07:33 AM
  #112
Motorman007's Avatar
Trader Rating: 87 (100%+)
Motorman007 is offline
Old 12-31-2016, 11:53 AM
  #113
why waste your time buying somethin that no one in the USA will carry just get spec three or b2102 it you arent going go any faster than stock and you modders out there can disagree me 100% and the only thing modding does is shorten the life of your engine seen done and moved on!!!
stoney452 is offline
Old 12-31-2016, 01:26 PM
  #114
hairymuffin's Avatar
Trader Rating: 99 (100%+)
Try rctracks Las Vegas, they had a ton there at the worlds. Most expensive off-road engine ever
hairymuffin is offline
Old 12-31-2016, 02:16 PM
  #115
Why is that one so expensive?
Cardiak is offline
Old 12-31-2016, 02:24 PM
  #116
Frank L's Avatar
Trader Rating: 148 (100%+)
Magic blue head....
Frank L is offline
Old 12-31-2016, 03:28 PM
  #117
Originally Posted by Frank L View Post
Magic blue head....
Well, glad I prefer red.
Cardiak is offline
Old 01-02-2017, 07:31 AM
  #118
Is that Ture with all modded nitro engines.. or with some?
WavyEnzo is offline
Old 01-02-2017, 10:48 AM
  #119
Cant drive's Avatar
Not true nessesarily. A modified engine can increase the RPM and power it produces which can wear the engine more than sock. But a reputable engine modifier can negate a lot of those effects with a lapped pistons and such. I have one of Neal's modded engine that has 9 gallons on it that has never been re pinched or had a bearing change and it still runs great. Not all modded engines are created equal imo
Cant drive is offline
Old 01-02-2017, 01:28 PM
  #120
Is Neal the top guy when it comes to modified engines?
Cardiak is offline
