Choosing nitro engine for Hobao Hyper SS
Gi,
I am fairly new to RC nitro and would to have your input on selecting the best nitro engine. I am planning to buy Hobao Hyper SS Nitro RTR. However it comes with 3 different kinds of engine and will appreciate your feedback on the differences with pros and cons on the engine. Eventually, recommending the best engine and also if you can list the engines in order of being latest. 1) Force JL .28 4 Port nitro engine 2) MachStar .28 6 Port nitro engine 3) Hyper .21 Race nitro engine. I see the option 1 is usually found in OFNA branded in U.S., while option 2 and 3 in U.K. Much appreciated. Also if you can advise on where I could get the best price online as I am based in United Arab Emirates. Thank you, Regards, Raza Azmi |
alpha engines are pretty great value .. they should have what you need... or a X act 21
Originally Posted by razaazmi
(Post 14072331)
Gi,
@DRaceMasta: Thank you for the note. But I only have the options to choose from the three i have listed so which one would be the best out of the three and why is what i am trying to learn and understand before buying one.
(Post 14073876)
Now that's another way of looking it in terms of time to run on a full tank.
However, I really would like to know what makes it so appealing to have Hyper7 as well as Hyper SS with .28 engine. Would more torque mean better buggy performance on hilly drives or grass etc. and what does more engine rev mean? Thank you for your inputs. |
(Post 14074144)
However, I really would like to know what makes it so appealing to have Hyper7 as well as Hyper SS with .28 engine. Would more torque mean better buggy performance on hilly drives or grass etc. and what does more engine rev mean? Thank you for your inputs. Usually a .28 engine won't run as fast as a .21 engine will. Say a certain .28 maxes out at 30,000 rpm and a good .21 maxes out at 40,000. You can use a clutch bell with more teeth with a .28 engine since they usually have more torque to get extra speed, but I don't think the bigger engines are any better in a buggy. People usually put them in monster trucks so that they can do wheelies easily. Simply: .28 usually has more torque, so quicker acceleration while a .21 has a higher rpm range and (usually) a higher top speed. I don't think the extra torque is worth the extra fuel that a .28 will use. Most people use .21 engines in their buggies. |
I have no experience with the Force.28....but I have used many Macstar.28 and Hyper.21...they are essentially the same engine but with a different bore....same carb/crank/rod/bearings/head/gudgeon pin/etc.
The Hyper.21 has a few more rpm at the top and the Macstar.28 has a little more torque down low...as expected. They are both pretty good RTR engines and if I could only choose one then I would have a hard time deciding which to go for...they are very similar in performance terms. As already said you can gear the larger engine differently to account for the torque/rpm differences between small and large engines...but in my experience there is not a great deal of difference with these two particular engines. |
I had a Hyper 7 PCR buggy years ago, it had the Hyper 8 port race engine, that thing got given a pretty hard time & went real well, was good on fuel & held a tune pretty well too. For an rtr engine it is pretty good & doesn't cost an arm & leg either.
Originally Posted by ozziii
(Post 14076243)
Thank you all for your help. I have bought Hobao Hyper SS.21 RTR. Will be breaking in next weekend.
| All times are GMT -7. It is currently 11:42 AM. |
