Like Tree36Likes
New break-in method
Old 03-06-2015, 06:27 AM
Default New break-in method
It is called break-in Dutch and wanted to get info on this. Check it out on www.redrc.net
ready rollers is offline
Old 03-06-2015, 09:42 AM
I'd be interested in seeing what kind of load that puts on the rod, rod bushings and crank pin with the engine being fully submersed in and I'm assuming filled with oil.
Werks is offline
Old 03-06-2015, 10:09 AM
rider313's Avatar
Trader Rating: 94 (100%+)
i was thinking the same thing Ron. It states they take temperatures in 2 locations so maybe the oil is heated or something. Kinda neat but I dont know if i would trust it compared to a engine that was actually fired up for break in.
rider313 is offline
Old 03-06-2015, 10:39 AM
Ccolemugen's Avatar
Trader Rating: 10 (92%+)
The system look like a good concept. I didn't see any filtration or circulation of the oil. It seemed to suck in and out the same oil through out the process. It looked like any metal particulates suspended in the oil are sucked in and out and not evacuated. I could be way off. Still looks like a great way to eliminate the breakin process for the customer.
Ccolemugen is offline
Old 03-06-2015, 06:46 PM
blktransam's Avatar
Trader Rating: 59 (100%+)
Reminds me of Mo Dentons way...
AlbertN likes this.
blktransam is offline
Old 03-06-2015, 08:10 PM
JoePit's Avatar
Trader Rating: 15 (100%+)
Solve that easily by disassembling the engine and cleaning prior to breakin.
JoePit is offline
Old 03-06-2015, 11:21 PM
No heat cycling going on there.
My ST-RR EVO is offline
Old 03-06-2015, 11:45 PM
houston's Avatar
Trader Rating: 96 (100%+)
Oh boii
houston is offline
Old 03-07-2015, 01:15 AM
houston's Avatar
Hmmmm
houston is offline
Old 03-07-2015, 05:16 AM
Not much more info on it accept there facebook page. There is allot of possibilities here.
Old 03-07-2015, 07:03 AM
bash bros's Avatar
Looks like I just found a new use for my deep fryer other than just fries!
bash bros is offline
Old 03-07-2015, 08:13 AM
Roelof's Avatar
Roelof is offline
Old 03-07-2015, 08:52 AM
Not liking it
1. can't do it at home
2. sounds pricey
3. sounds like a way to knock out a conrod real quick
4. during break in you are adapting sealing surfaces to eachother, this requires heat cycling, also ideally you want to maintain operational temperature 100-120c, which is the range you will be racing at.
Not for me.
Eivind E is offline
Old 03-07-2015, 09:27 AM
I agree.. A lot of effort to reinvent the wheel. It's like they say about the US investing millions to come up with a pen that works in space.., while the Russians just used a pencil. People need to lighten up about break-in and nitro in general. Doesn't need to be rocket science. Put five sensible heat cycle tanks through it then run it on the rich side for a liter or two and done...
Herrsavage is offline
Old 03-07-2015, 02:12 PM
JoePit's Avatar
I like the idea if it works. No noise and you could do it inside. With that being said I would consider buying the unit. Sending engines back and forth not for me.
JoePit is offline
