REX Engines USA
Old 12-24-2014, 09:59 AM
Hoese37's Avatar
Default REX Engines USA
A familiar name has come back to the nitro engine game. REX/Novarossi car engines are back. 4 new .21 mills and a .28.
First up the Paloma .21: Looks like the Keep Off .21-7XL
TECH SPECS:
Displacement: 3,49 cc
R.P.M. (max power): 35.800 RPM
Practical range: 6.000-40.700 R.P.M.
Bore x stroke: 15,88x17,60 mm
Sleeve: 7 ports
R21 Plus5: Looks to be the same as the P5
TECH SPECS;
R.P.M. (max power): 34.500 RPM
Practical range: 6.000-36.200 R.P.M.
Bore x stroke: 16,26x16,80 mm
Sleeve: 5 ports
R21 Plus8: Looks to be the 421SB/821SB
TECH SPECS:
R.P.M. (max power): 36.200 RPM
Practical range: 6.000-40.200 R.P.M.
Sleeve: 8 ports
Hoese37 is offline
Old 12-24-2014, 10:01 AM
Hoese37's Avatar
R28-7M:
TECH SPECS:
Displacement: 4,66 cc
R.P.M. (max power): 33.500 RPM
Practical range: 6.000-38.200 R.P.M.
Bore x stroke: 18,35x17,60 mm
Sleeve: 7 ports
Hoese37 is offline
Old 12-24-2014, 10:16 AM
22Racer's Avatar
Trader Rating: 67 (100%+)
Plus 5 is nothing like a P5, 14.5mm weighted crank, different sleeve etc.
Rex
22Racer is offline
Old 12-24-2014, 11:32 AM
Hoese37's Avatar
Im just comparing by part numbers at the moment. Im sure there are differences, as these seem to be some classic Nova mills, with updated internals to bring them up to spec with the current models.
Hoese37 is offline
Old 12-24-2014, 02:59 PM
GarrettMcKamie's Avatar
Trader Rating: 18 (100%+)
Almost have a gallon on my Plus 5 and loving it! Getting around 10.5 mins on a tank and not fully broken in yet with killer power. 41021 header 9901ss pipe Vp Powermaster fuel on TLR 3.0
GarrettMcKamie is offline
Old 12-24-2014, 11:15 PM
The Plus 5 is very similar to the Novarossi BTT. With more power in the mid and top end. It has a very usable power band. We are getting great run times.
Dcracing2 is offline
Old 12-25-2014, 01:09 PM
mercfocus's Avatar
Got the Paloma 21 a couple months ago.
This one here:
http://rex-usa.com/R-PALOMA21-LIMITE...RPALOMA21L.htm
Awesome!
Running it with a JP4 and Sidewinder 30%. I think it's made the OFNA I put it in into possibly my fastest car.
Had to change the front bearing already at about 1 gallon but for $15, that was no big deal.
I was going to order the 9901 SuperStrong to see what difference it will make but xmas sorta made me wait til the payday.
Attached Thumbnails REX Engines USA-dsc00024.jpg   REX Engines USA-dsc00244.jpg   REX Engines USA-dsc00512.jpg   REX Engines USA-dsc01301.jpg   REX Engines USA-dsc09863.jpg
mercfocus is offline
Old 12-25-2014, 01:32 PM
mercfocus's Avatar
Oh ya, and what I forgot to mention:
When I changed the bearing, I saw a lot of the same Nova parts in there. The R7 rod and the piston & sleeve looked pretty much exactly like my Beat 5.
The carbs are for sure the same. That's obvious but the Rex didn't have that extra tight head button and O-ring like my Beat 5.
And I finally just found one of my pics of my Rex out of the car.
Old 12-25-2014, 01:36 PM
croracer's Avatar
whats the difference in the limited paloma vs the blue paloma, besides the orange head?
croracer is offline
Old 12-25-2014, 02:33 PM
mercfocus's Avatar
From what I understand, the blue head is a 5 port and the orange head is a 7 port.
There's also something I read in RC Driver magazine about the size difference in the crank and one other thing but I don't remember what it was.
Old 12-25-2014, 02:41 PM
mercfocus's Avatar
Upon further inspection, I see I might have had it confused with the 5 port.
The blue head Paloma is probably also a 7 port.
Tring to find what I did with that mag issue that talks about this.
Old 12-25-2014, 07:53 PM
22Racer's Avatar
The Paloma and the Paloma limited are quite different. The Limited is a standard long stroke 7 port, I thought it looked similar to a Fusion X7. The Blue head Paloma is basically a Nova Bonito, 7 port extra long stroke.
Rex
22Racer is offline
Old 12-25-2014, 08:50 PM
hambone's Avatar
Rex
Rex, how does the 5 port sleeve differ from P5?
hambone is offline
Old 12-26-2014, 07:58 AM
houston's Avatar
Trader Rating: 96 (100%+)
Rex
You mean an older plus 2 367?
These are old spare parts engines so nova can recoop some money from dead inventory
Not saying its a bad thing just dfrnt
houston is offline
Old 12-26-2014, 08:03 AM
am
Like Rb limited series engines :-)
am is offline
