question about my clutch
Old 11-05-2014, 12:38 AM
Default question about my clutch
so the spring in my clutch broke and I'm getting that replaced would that be the reason why my car doesn't stay idleing or should I look for other problems I have a tlr-sct nitro
cadove93 is offline
Old 11-05-2014, 01:47 AM
Roelof's Avatar
It is the same as in a real car as engaging the clutch while standing still or hitting the brakes. The motor will stall. Yes, that is the cause.
Roelof is offline
Old 11-05-2014, 01:50 AM
HomicidalBunny's Avatar
It could be acting like something stopping the flywheel. Does your engine cut out immediately or soon after you let off the throttle or come to a stop?
EDIT: What he^ (Roelof) said
HomicidalBunny is offline
Old 11-05-2014, 02:02 AM
Thank you I thought it might be the clutch and it dies when I let off the throttle I have to hold the throttle at about 1/4 position to get it to start
cadove93 is offline
Old 11-05-2014, 11:34 AM
Fix your clutch and re-assess your idle. There are too many variables to be certain it is / was your clutch.
gapwmu is offline
Old 11-05-2014, 11:13 PM
Thank you I will fix the clutch and check to see if it idles
cadove93 is offline
