Question on priming
Old 10-26-2014, 10:17 AM
GAJ
Questions?? Question on priming
Is the intention of priming to get fuel to the carb, or to get fuel into the engine block?
I do not have much success with blocking the exhaust and pulling the pull start, whereas I am more successful disconnecting the line from the exhaust and blowing through it.
Should the priming be done with the throttle closed, or open?
I do not know if my issue is flooding the engine, or starving the engine.
Thanks.
GAJ is offline
Old 10-26-2014, 10:45 AM
merdith6's Avatar
Default Good question
I agree with blowing into the exhaust line to prime the engine. You are doing the right thing. I have noticed with some engines I need to open the throttle just a little to get the fuel to the carb so it won't hurt to open it a little. Stop priming when the fuel gets to the carb. That will prevent flooding the engine.
merdith6 is offline
Old 10-26-2014, 10:50 AM
madweazl's Avatar
If you're having trouble, you're probably too lean on the LSN right now. Try coming out a full half turn and see if that helps you out. I do typically give a bit of throttle at cold start (idle up on my radio is set around 15%) however.
madweazl is offline
Old 10-26-2014, 12:04 PM
Men in Suits's Avatar
Start it and go.
Men in Suits is offline
