Ninja B02 = OS which engine?
Old 10-20-2014, 09:26 PM
Default Ninja B02 = OS which engine?
anyone can help please!
Ninja B02 what im using and i want to change piston and sleeve, if i want to use OS piston and sleeve do you guys know which one ?
Thank you!!!
bestlap is offline
Old 10-21-2014, 12:55 AM
am
I belive you can use XZB speed.
am is offline
Old 10-21-2014, 03:08 AM
JsK
JsK's Avatar
Thank you!!!
Wow if you do a google search for " ninja b02 piston and sleeve" at least 2 Chinese scam sites pop up. Be very careful who you buy from. A genuine set is going to cost at least 150.00 or close to it.
JsK is offline
Old 10-21-2014, 10:46 AM
The hudy fx royal is very close un power compare with the ninja ... I owned both
segreda is offline
Old 10-21-2014, 11:03 PM
Trader Rating: 21 (100%+)
i really hope u didnt prompt this guy into buying an fx piston and sleeve to replace inside his ninja bro. next time try read his question insteading of spamming your fanboy blabber...
Matt Piva is offline
Old 10-22-2014, 07:11 AM
Not going to start a fight .... Some body needs love i think ... Good day
segreda is offline
Old 10-23-2014, 08:19 AM
Hoese37's Avatar
The XZB Speed is almost identical, but the timing is slightly different. The Ninja has the power shifted to the upper part of the RPM band. The Speed is more linear.
Hoese37 is offline
Old 10-23-2014, 06:17 PM
22Racer's Avatar
Trader Rating: 67 (100%+)
It might fit!
Rex
22Racer is offline
