Switching fuels
Old 09-30-2014, 05:00 PM
  #31
HomicidalBunny's Avatar
Originally Posted by Lille-bror
FX engine is not OS based engines! only the plugs :-)
Ah yes I forgot that's what I had written. I meant to say that the head button was "OS based" because it uses OS based plugs.
HomicidalBunny is offline
Old 09-30-2014, 05:01 PM
  #32
Originally Posted by blis
Other than tuning, the only cause for concern would be in case there is an adverse reaction between the fuel types or after run.
Put some old fuel in a jar, add some new and leave it over night, do the same with after run and check it doesn't coagulate (turn to blobs) or precipitate (create solids)
It's probably a good time for a tear down and bearing flush.
I'm going to have to muster a lot of courage to crack open my engine again Last time I did, I found a surprise score on my piston
How do you flush the bearings? Nitro engine cleaner (with bearings out of the crankcase of course)?
Old 09-30-2014, 05:23 PM
  #33
grizz1's Avatar
Just run the motor right out of the old fuel unit it won't start with the glow igniter on.
The Werks fuel won't be an issue. Just fire it up and re-tune to the Race Blend.
grizz1 is offline
Old 09-30-2014, 05:31 PM
  #34
Sounds like a plan
Old 09-30-2014, 07:10 PM
  #35
Clockwork has fuel and it's amazing
Chief88 is offline
Old 10-01-2014, 10:20 AM
  #36
Yep, it's actually Clock Werks fuel and it's a product that we make for them. So anyone that is looking to try our fuel in Canada please give Neil a call and order some!
Werks is offline
