Clunk VS Non-Clunk tanks
#16
Ok now I'm getting it, if you were to have more fuel capacity then legal you could simply pull the fuel line into the tank further after the race to make it seem legal. Ya I could see that being illegal, my next question would be now what is the correct fuel tube length inside the tank for legal fuel limit? Guess you would have to test it.
#17
all tanks are different some are way smaller and use long fuel lines to bring up to 125ml max others are a lot closer and need only smaller length of fuel tube to make the legal 125ml
#18
#19
Makes sense
#27
#29
#30
Just lately it was becoming very difficult to tune both my new identical GO GXII-5RHO engines, which replaced the too powerful OS and Picco engines that were originally installed.*
After exhaustive diagnostics, I finally pulled the tube and filter assembly from one of the tanks and sucked on the opposite end of the 'Bead' filter. Guess what!! It was like trying to draw a thickshake through a cocktail straw, little wonder my engines were starved of fuel.
After breaking down one of the brass bead filters for deeper analysis, I discovered that (Shown in attached photo) :-
(A) The narrowest part of the beads is the only area that fuel passes through, not a smart design feature. Might be OK for .12 engines.
(B) The bulk area of brass beads appear to be only used for extra weight!
(B Yellow Arrow) The pipe is moved around purely for picture clarity, my clunks have never moved out of their guide walls on their own.
I have now modified both my fuel line systems, and so far the results are awesome, just waiting now to see how it goes at our next club meet.
*Our local clay/agrogate track has poor grip with high power engines, which also results in excessive tyre wear. Not normally a problem if one is challenging our 'Ace' drivers in a Worlds final being held on a track such as ours. But I don't have the skills nor finances to absorb one race tyre sets ;-(
Last edited by Palebushman; 03-11-2016 at 01:23 AM. Reason: Clarity of photo markers.
