Engine help please
hi, i have a hsp warhead and i haven't exactly used it for a while, so i started it the other day (it had had no current issues prior to this) and once it was going i noticed that fuel was seeping through underneath the glow igniter in the engine. I got the buggy out later that day and the same thing happened again.
can anyone please help me here? if more description is needed just ask |
Tighten the glow plug and the cooling head screws
+1 what jaz240 said also you can check the washer under the plug to make sure its not warped
Moved to engine forum
| All times are GMT -7. It is currently 05:44 AM. |
