Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
How Should an Engine Look inside after a Day Racing? >
Old 06-09-2014, 05:40 AM
BPro's Avatar
Default How Should an Engine Look inside after a Day Racing?
Hey Guys Just Checking out my engine and was wondering if it's normal for the piston to be so darkened after a days racing our is it a sign of running to rich or to lean. The engine is a gallon old. Thanks.
BPro is offline
Old 06-09-2014, 05:54 AM
BPro's Avatar
Also the Fuel is VP masterfuel 30%
BPro is offline
Old 06-09-2014, 06:40 AM
Usually that sort excessive carbon buildup means either your fuel is rubbish, or your engine has lost all its compression and is re-combusting already combusted fuels.
Since your engine is only 1 gallon old, I'll go with "you're allegedly running rubbish fuel".
I've never tried this fuel, so before they go and take me to court, I'd like to make it clear that this is just guesswork and stick an "allegedly" in there.
Ps. I've also seen similar results from ingested dusty sand particles, but that would leave scratches on the sides of the piston. If your engine has good compression and no scratches on piston, change your brand of fuel.
Eivind E is offline
Old 06-09-2014, 06:57 AM
That looks fine. A golden brown color just shows you're making power. If there is any castor in the fuel it will deposit a slight golden to brown deposit. It actually protects the engine.
If there is no color whatsoever you're way rich and not making power and wasting fuel.
Go back to the track and have fun.
SManMTB is offline
Old 06-09-2014, 08:40 AM
MotoGod's Avatar
Trader Rating: 118 (100%+)
Doesn't look too bad really. Castor oil does add deposits like that as it burns. It might be a bit excessive, but if the engine is still new (1 gallon or so) all the deposits left from break in are probably still there as well. Some will burn off as you race it. Feel free to clean them off gently....but I never bother unless it's really built up.
I wouldn't worry about it too much, but just a tip....clean the outside of your engine before you crack it open like that ;-)
MotoGod is offline
Old 06-09-2014, 08:51 AM
I think its too dark. Looking at my engine that has 6 gallons on it, its not that dark.... Go Byrons.......
token is offline
Old 06-09-2014, 08:52 AM
Hoese37's Avatar
Piston looks fine. Golden brown is perfect. If its still looking like new, youre too rich. If its black youre too lean.
Hoese37 is offline
Old 06-09-2014, 08:59 AM
Roelof's Avatar
You probably have not runned many different fuels. This is normal for a castor based fuel and a rich setting and/or low compression has indeed a factor in it.
We have experemented with several oils to make a fuel, Shell Advance Racing-M was the one with very good results but with a dark black color all over the place inside the engine without hurting the engine.
Roelof is offline
Old 06-09-2014, 09:20 AM
Maximo's Avatar
Foe one gallon you have slightly more carbon then you should...means you were running rich, or there was a buildup of excess castor oil... But nothing looks abnormal.....
Maximo is offline
Old 06-09-2014, 05:35 PM
BPro's Avatar
Hello the engine has been running rich due to the break in process, i won't say it has a loss of compression because i can't crank the engine over at the flywheel with my hand unless i apply a lot of force which I'm not comfortable doing why the engine is cold. Thank you for your reply and insight.
BPro is offline
Old 06-09-2014, 05:37 PM
BPro's Avatar
MotoGod how do you clean your engine before dismantling it any tips would be greatly appreciated.
BPro is offline
Old 06-09-2014, 05:39 PM
BPro's Avatar
Thank you very much.
BPro is offline
Old 06-09-2014, 05:41 PM
BPro's Avatar
Just another thing do you guys give your piston and sleeves a good clean every couple of gallons or so? and if yes what do you use? Thanks.
BPro is offline
Old 06-09-2014, 05:45 PM
BigInJapan's Avatar
Trader Rating: 18 (100%+)
If you wanna clean the insides, use gasoline with about 5-10% oil added
BigInJapan is offline
Old 06-09-2014, 06:10 PM
wingracer's Avatar
Trader Rating: 24 (100%+)
No, never unless carbon build up is extreme such as chunks flaking off or clogging the multi-exhaust ports which never happens unless you're using some crazy high carbon fuel.
wingracer is online now
