LRP Spec 3 .28 Backplate
Old 05-22-2014, 07:48 PM
Default LRP Spec 3 .28 Backplate
I have an LRP .28 pull start that I would like to change over to a non pull start engine but cannot seem to find a plain backplate for this engine. LRP does not list one on their website. Does anyone know of a similar engine from which the backplate would fit on this? Searching through back postings it seems that the SH engines are the same and possibly the OS XZB. Towerhobbies does have a backplate for the 21 XZB but I 'm not sure if it will fit. Does anyone know if it will fit or have one they would like to sell?
AlGio is offline
Old 05-23-2014, 12:06 AM
Roelof's Avatar
This LRP is made by SH and SH makes for a lot of brands engines.
Roelof is offline
Old 05-23-2014, 12:19 AM
Trader Rating: 61 (100%+)
I use this for my LRP 28 on my Savage.
http://www.amain.com/product_info.ph...sembly-26-427/
mr240 is offline
Old 05-23-2014, 02:05 AM
Roelof's Avatar
http://www.go-modellbau.de/backplate...26/28-uae.html
http://comparerc.com/#!/search?q=lrp...ackplate-3a7cc
http://comparerc.com/#!/search?q=lrp...ll-start-7d4cf
Roelof is offline
Old 05-23-2014, 06:54 AM
Hi and thanks for the replies but none of plain backplates are in stock. I will have to try and see if I can find any for the SH engine.
AlGio is offline
Old 05-25-2014, 03:40 PM
Anf
The Losi 454 backplate will fit...as you have the pull start crank then you will need to file off the end of the crank pin to fit any closed backplate for this engine.
Anf is offline
Old 05-25-2014, 11:16 PM
DYN0960 is what you want. It has a slot for the pin. No filing or anything of the sort. Pop off the old one, pop this one on(carefully, making sure the pin on the rod is in the right position..) It works on the LRP 28, Dynamite Big Red 28, Mach 427, SH, Losi, Nosram, etc etc... Used to be a Sportwerks part number, but now is Dymamite..
This is what you want:
http://www.losipartshouse.com/DYN0960-p/dyn0960.htm
Herrsavage is offline
Old 05-28-2014, 05:59 PM
That is exactly what I was looking for! I already ordered one for the SH 28 but will need to cut off the pin. I may have to order this one as well.
AlGio is offline
