Measuring idle gap
Old 05-14-2014, 08:36 AM
Default Measuring idle gap
There are varying recommendations for idle gap. Just curious how people are measuring it.
Cheers
picko990 is offline
Old 05-14-2014, 08:59 AM
Motorman007's Avatar
Trader Rating: 88 (100%+)
Cheers
http://www.aliexpress.com/item/0-3-1...876285348.html
http://www.amazon.com/61-80-Diamond-.../dp/B00DE8NDO0
Motorman007 is offline
Old 05-14-2014, 12:56 PM
Stubbs's Avatar
Trader Rating: 58 (100%+)
I measured a paper clip I had on my desk, and it was 0.6mm. I keep that in my tool box, and use it if I need to set idle gap. I don't have to use it very often though....
Stubbs is offline
Old 05-14-2014, 06:27 PM
ozziii's Avatar
+1 for paper clips, I keep a pack in the toolbox, .6mm as well, have a couple of .8mm clips but thats a little big.
ozziii is offline
Old 05-15-2014, 10:03 AM
What!!!! I thought I was the only one that used the paper clips.
That sucks.
Hahah
Franchise is offline
Old 05-15-2014, 11:00 AM
RCmayor's Avatar
Measure with ears. All that is needed.
RCmayor is offline
Old 05-15-2014, 11:26 AM
I was gonna say why would you measure it?
SuperDaveNT is offline
Old 05-15-2014, 11:46 AM
Stubbs's Avatar
Yep....only time I measure it is if I'm setting my carb back to facotry settings for some reason.
Stubbs is offline
Old 05-15-2014, 07:29 PM
Thanks for the great ideas. I thought about using the verniers and something else later in the evening.
picko990 is offline
Old 05-15-2014, 08:57 PM
You know what I probably could do it by ear. Why would I if I have a clip that makes it easier to set the gap to what the manufacturer says to.
Why do we measure shock oil? 35wt 40wt
And diff oil.
Why do we balance tires?
Why do we use springs with colors specifying the spring rate?
Because it is all best practice for performance.
It relieves me when I don't have to guess because without that clip that's exactly what it would be is a guess.
Plus I like my clip. Hahah.
Old 05-16-2014, 06:23 AM
Pit-racer's Avatar
Back in the day ...I've seen Ron Paris did it by ear and sight when tuning young Swauger's car . Works for me. But I see what you mean.
Pit-racer is offline
Old 05-16-2014, 07:47 PM
PAPER CLIP!!!!
Deckman is offline
Old 05-17-2014, 03:08 AM
Roelof's Avatar
Tell me how to measure silicone oil? To my knowledge we only trust what the bottle says. The same with springs or do we all have a spring rate meter?
The problem is that the idle gap is not a steady thing working on its own or determing other settings. It is the last adjustment to the carb in finding the right tune and it is really a setting which must be done on a feeling or sound. The LSN and HSN together the the kind of fuel and weather is finally determing the idle gap.
Roelof is offline
Old 05-17-2014, 08:53 AM
Frank L's Avatar
Trader Rating: 148 (100%+)
Frank L is offline
Old 05-17-2014, 11:03 AM
I don't measure it. Your right. I trust losi on that one. But it is measured. :-)
Your right on the gap being only a part of the a steady idle. I think that part confuses a lot of newbies
I traded some tires for an engine I knew had less than two gallons on it. The guy just got frustrated with it. I checked the carb and the gap wasn't off at all but the tuning was all screwed up. A new plug about 15 mins of tuning and it was a different machine.
I still ended up putting my werks carb on it though.
