ninja bo1a
There's a brand new never seen fuel techno power .21 on eBay for 150.00 ! Same engine and about the same price as a piston sleeve and rod set !
It will be very hard to find the 5 port Sleeve that was used in the B01 or B01a engines. But you could replace it with the old OS 3 port sleeve from the Speed VZB, which you can still buy on Amain. The B02 is basically the same as the OS Speed XZB and that sleeve would not work.
Good Luck - The B01's were my favorite engine, it sucks they stopped making them.
MR-21 B01 was Mario Rossi made by GRP/tecnomeccani or whatever they're called
JX-21 B01 and B01A were both OS, based on VZ-B in an XZ-B case but with slightly different timings and B01A had a drilled/lightened heatsink head
B02 was still OS based but based off XZ-B stroke rather than VZ-B.
MR-21 B01 and JX-21 B01 have same timings. B01A is the better engine.
Isn't the arrow gtr II a copy of the ninja ?
No.
If you have the os jx21 bo1a,get the arrow gtr p/s/r from ebay for about 80-100$.
I would think if timing not right motor would run lime garbage. Wish there was parts still for this motor. I love it. Was looking for a better rebuild than having it pinched. Prolly gunna get pinched and run it for a minute and buy something a lill later. Thanx for all help guys. Some good info here. And yes it is a jx 21 b01a
It's not really a 5-port though. Usually this sort of extra port is called a +2.
5-port is usually said if the side ports are split in the middle, so the side ports are two side-by-side, meaning it's a 5-port, as opposed to a 3-port which then only has one really wide port on each side.
The arrow gtr II on the other hand doesn't have any side-by-side port, it has the same port on the side as before, and then it has an extra, smaller hole below the port.
Some manufacturers, for example Alpha, has this on some engines, like their F850 vs their A852. The A852 porting is +2, as it has this hole below, but it's definately not a 7-port.
So as far as that goes, Arrow GTR II is not a 5-port, it's the same 3-port, but with a small hole on the side BELOW the actual port, so it's a 3+2. Still a 3-port!
I don't think there'd be any actual performance increase, but I do think this small hole helps with lubrication of the piston. I'm not sure if the piston actually goes far enough down for this extra lower hole to function as an intake, so as such I figure it only helps for the actual lubrication.
