Looking for Timing Specs
What are the timing specs for the engines that are used for nitro off-road racing?
Looking for: Exhaust duration Transfers duration Boost duration Crank duration Blowdown Head clearance Recommended Nitro/oil percentage ? Thanks, David |
Thanks for the link!
Interesting to note that most of those engines run under less than 180 degrees exhaust timing considering the high rpm's they turn. Still would like to know what head clearance racers are using. On my .21 it's set at .006 . David |
Originally Posted by dbuck
(Post 12827520)
Interesting to note that most of those engines run under less than 180 degrees exhaust timing considering the high rpm's they turn. Still would like to know what head clearance racers are using. On my .21 it's set at .006 . David Onroad, it's more like 25-40k, thus more duration. |
In my list mostly onroad engines: http://www.euronet.nl/users/tooms/timings/timings.jpg
Head clearance is determed by the combustion chamber. Older Novarossi's were set to 0.7 and later are set to 0.55. Picco is at 0.5 or even 0.4 so far I have seen (@ 25% nitro). Also the headclearance is set by the nitro percentage. |
| All times are GMT -7. It is currently 11:47 PM. |
