Originally Posted by merdith6
(Post 12816013)
You dirty glowplug hole
Originally Posted by THE PHILLY JYNX
(Post 12812988)
Running a much hotter plug will help reduce the issue but the fact is its still MASKING the problem...leaking front bearing... Notice I did not say BAD front bearing. Bearings in these engines are not seals... And this issue is by no means isolated to Werks engines. In fact your BTT just proves that point. I have tested for vacuum leaks on brand new never ran nova plus 4's. The first 2 tanks 250 cc's they passed the break cleaner test with zero issues. By tank 3 the engine was studdering. On the 4th tank, 500 cc's i could kill the engine instantly. This was with brand new nova 17011 bearings. So by the time we finish the break in process we are already masking a leaking front bearing with carburetor jetting.
Originally Posted by Rsickles
(Post 12816888)
So O.S. and Novarossi are selling brand new $500 on-road engines that are just paper weights, because they have metal shielded front bearings? Plus these .21's are pulling more RPM's and even more vacuum... so how one but not the other? And the air filters on our off-road cars are no more restrictive than the INS Boxes they run.
The seal is between the crank and crankshaft. If the torerance is to big, you will have problems. There is no difference between onroad and offroad engines. Our engines runs a bit hotter, and onroad fuel might have more castor oil it. That helps a little as it will also seal better between the crankcase and crankshaft |
(Post 12816888)
Nice debat :)
Back to the Werks engine. Normally there is nothing wrong with a product, and I still think those B6 engines are some of the most powerfull engines on the market. Very impressive for sure. Tried Nova carb on it, HIIIIGH idle speed, low, rich lean, different clutches, more and less compression, different cars, new fuel lines, new airfilter... Still flames... Sometimes after WOT, sometimes after few seconds of idle, sometimes after moderate gas on the slower parts of the track... I guess we were just unlucky. I've changed the front bearing with a brand new Boca bearing and will break it in, and test the engine on the track when winter is over. But I still think we've done something wrong and the engine doesn't have any fault... I just don't know what :-) |
Haha
Originally Posted by Eivind E
(Post 12816770)
That is the best insult I've ever heard!
I fix a few engines with flamouts with the Buku cap this seasson Bjarne. Ge one and try!The new front bearing will last alot longer to :-)
Originally Posted by am
(Post 12820106)
I don't think he is interresting in using more time\money on the engine. As far as I can see, you'll need a specific Buku cap for the Werks engine. Well, if it doesn't help with the new bearing, I'll block the vakuum hole and test the engine again. As mentioned, its a damn powerfull engine, so it must produce a lot of vakuum |
here is question I have a rebuilt os speed 21 that i bought second hand the other day when I was running it at idle I heard a whoosing sound coming from the front of the engine.
I know that my clutch bell is junk and I am in the process of replacing it. But I was wondering if this a sign that front bearing is going bad. The engine ran great on the track as it tuned very easy and it kept the tune all thru the run. michael |
Originally Posted by stoney452
(Post 12829811)
I know that my clutch bell is junk and I am in the process of replacing it. But I was wondering if this a sign that front bearing is going bad. The engine ran great on the track as it tuned very easy and it kept the tune all thru the run. michael You can make a quick test: at idle speed, grab around the cooling head (without burning yourself). If the whooshing sound stops, you most likely have a defective REAR bearing. Open the engine and check for rust on the bearings, before you starts the engine again. |
Originally Posted by Lille-bror
(Post 12831210)
Hi.
You can make a quick test: at idle speed, grab around the cooling head (without burning yourself). If the whooshing sound stops, you most likely have a defective REAR bearing. Open the engine and check for rust on the bearings, before you starts the engine again. I will do that as soon as i get to run it again thanks michael |
| All times are GMT -7. It is currently 08:11 AM. |
