-   Offroad Nitro Engine Forum (https://www.rctech.net/forum/offroad-nitro-engine-forum-157/)
-   -   PICCO/OFNA .26 PART NUMBERS PLEASE HELP (https://www.rctech.net/forum/offroad-nitro-engine-forum/766804-picco-ofna-26-part-numbers-please-help.html)
ryconinc 10-22-2013 11:59 PM
Hi I have a OFNA 51214 PICCO .26 Outlaw Big Block for 1/8 scale -Pull-Start and my nephew blew the motor. I really like the motor and want to rebuild it. Can anyone please help me and let me know where I can find part numbers for it so I can look for the correct parts?? Thanks a million!!
Maximo 10-23-2013 03:05 AM
the parts are a long time discontinued..so you may have trouble finding parts....
Maximo 10-23-2013 06:31 AM
For what your going to pay to rebuild that engine you would be better off just to start fresh ..You can buy a new Picco Boost 28 for just over $200.00 and it will be every bit as much engine and more then that 26.......When you consider with a rebuild you need new bearings,piston/sleeve,rod,wristpin your going to spend nearly $200 anyways.....Also consider that your 26 may have wear on the crankpin....sometimes the cranks are quite worn and not worth putting a new rod onto......So basically when a old engine gets blown up its often not worth rebuilding, often cheaper and easier to just buy a fresh new engine and start from scratch........
motomatt 10-23-2013 06:39 AM
This is the current Picco. Picco Boost 28
http://tritonrc.com/index_htm_files/4610.jpg
