Engine stalls at WOT
Old 06-28-2013, 04:15 AM
turbo5513's Avatar
Questions?? Engine stalls at WOT
Ok, so the car seems responsive in the low to mid range speeds but as soon as I give it full throttle, it dies with some more smoke blue coming out of the exhaust. I tried leaning the HSN more than half a turn but it made a slight to no difference. This car was running perfect in winter but I have never tuned a car in summer. Here are the weather conditions: The temps are around 30C outside,the barometric pressure is 1016 millibar and the humidity is 54%. I also checked to see if the air filter was a restriction but it isn't. The fuel is new and my glow plug has about 5 litres of usage on it. What should I do?
turbo5513 is offline
Old 06-28-2013, 04:33 AM
Winner's Circle's Avatar
Try richening the HSN. Usually when the engine dies at high rpm it is because the HSN mixture is too lean.
Good luck.
Lee
Winner's Circle is offline
Old 06-28-2013, 04:47 AM
check your servo linkage too. some motors do not like it when you do not have that little "play" in the carb at WOT. if that is not it, I have been taught this is all LSN
I would richen LSN. worked for me.
bohdi is offline
Old 06-28-2013, 04:52 AM
turbo5513's Avatar
Good luck.
Lee
Hi,
I tried to richen the HSN but it only made it bog more and leaning it didn't help either?
Old 06-28-2013, 05:09 AM
Roelof's Avatar
Did you change the glowplug?
Roelof is offline
Old 06-28-2013, 06:39 AM
Hoese37's Avatar
Reset it back to factory and start again.
Hoese37 is offline
Old 06-28-2013, 07:26 AM
JoePit's Avatar
Trader Rating: 15 (100%+)
It doesn't sound like a tuning issue. How's the compression? Usually when engines start ghost flaming like that it's a mechanical issue. A front bearing leak would be a prime suspect IMO. Check the clutch also.
JoePit is offline
Old 06-28-2013, 07:46 AM
turbo5513's Avatar
Thanks guys I fixed the problem. The LSN needed to be richened 1/4 turn, I needed a new glow plug and I needed to lean the HSN. Time of some bashing
Old 06-29-2013, 06:48 AM
xristoz's Avatar
Good to hear that you solved your engine issue.
xristoz is offline
Old 07-25-2013, 06:06 AM
My friends lrp 30 does the same..it will run 1/2throttle but as soon as we hit wot it dies ..its a new engine.just broken in.what can cause this?we are on the rich side already.the hsn is on 3.5 while the lsn is flush on the bevel.any ideas?
m0thertruckah1 is offline
Old 07-25-2013, 06:33 AM
alexrckid's Avatar
double check to make sure that the entire FUEL SYSTEM is "air-leak" free...and that goes for the exhaust side as well.......either one can be causing the carb to detect a lean condition at full throttle.........
alexrckid is offline
Old 07-25-2013, 10:58 AM
Tubing is new..plug is new..just cant go wot!it sux!
Old 07-25-2013, 11:39 AM
sschultz's Avatar
Try leaning it out a few hours.
sschultz is offline
Old 07-25-2013, 09:55 PM
Angry
both needles?
thanks!
Old 07-26-2013, 05:10 AM
sschultz's Avatar
both needles?
thanks!
If it idles good and after 10 seconds of idling, it revs clean, lsn is good. You problem lies with the HSN.
sschultz is offline
