Help out a NOOB please
Old 05-13-2013, 05:21 PM
Suspended
Cool Help out a NOOB please
Just want to know what is after run oil how do you us it and is there any other matinece items i should have?
GVMAN is offline
Old 05-13-2013, 05:34 PM
Jhughes's Avatar
After run oil is a synthetic lubricant that prevents corrosion and gum build up. You need to remove the glow plug, then put about 4 drops into where the glow plug was, then rotate the flywheel several times, then insert your glow plug and you're done.
Jhughes is offline
Old 05-13-2013, 05:45 PM
Suspended
Thumbs up thanks
thanks is there any other after or befor run matinece i should buy or carry out
GVMAN is offline
Old 05-13-2013, 07:40 PM
Jhughes's Avatar
Check out the youtube chanel squirrelod, in his videos he will tell you anything you could ever need to know about a nitro engine and how to maintain it.
Jhughes is offline
