Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
The Official FX Royal Racing Engine Thread >
Like Tree11Likes
Old 08-05-2016, 11:40 PM
  #1606
Originally Posted by toyoter91 View Post
I have been running just the regular medium.
Also, I ran the K3 all weekend at the Sidewinder race in vegas and it's probably the best buggy engine I have ever ran. Feels a lot like a B2101 but with more top end.
Sweet mills but run a JP Dirt and you'll never want to run another engine again. Yes there are some mills out there that get slightly better run time probably but its not worth it compared to how much more smooth and fast the JPs are.
sn47som1 is offline
Old 08-07-2016, 02:13 AM
  #1607
Tried reading through the thread for info on any FX on road engines. Anyone know if they have ever produced, currently produce, or plan on producing any .21 on road engines?
Glutton is offline
Old 08-08-2016, 10:45 PM
  #1608
Super Moderator
1/8 IC Fan's Avatar
Trader Rating: 85 (100%+)
They were going to make the R9 I believe, but not sure what the holdup is.
1/8 IC Fan is offline
Old 08-09-2016, 12:03 AM
  #1609
K3 is same carb? long needle like K5?
gt racing is offline
Old 08-09-2016, 07:54 AM
  #1610
toyoter91's Avatar
Trader Rating: 47 (100%+)
Yeah, looks to be the same carb according to the part numbers.
toyoter91 is offline
Old 08-11-2016, 05:27 AM
  #1611
yep EXACTLY the same in every part, barr the liner which has 3 ports.
clarkie_ni is offline
Old 08-11-2016, 11:01 AM
  #1612
toyoter91's Avatar
Not true.
Crankcase, backplate, head button, piston, piston pin, piston pin clips, rod, crank and sleeve are all new part numbers.
The K3 has a shorter stroke than the K5.
Old 08-11-2016, 12:28 PM
  #1613
Roelof's Avatar
And a 25.8 main bearing..... which I think it is a bit strange because there is one brand using them and all others with a 14mm crankshaft use a 25.4 bearing.
Roelof is offline
Old 08-11-2016, 05:24 PM
  #1614
toyoter91's Avatar
The K5 also runs the 25.8 rear bearing.
Old 08-11-2016, 06:10 PM
  #1615
Vinny Cancilla's Avatar
Not true.
Plus a bigger bore.
Vinny Cancilla is offline
Old 09-14-2016, 01:15 AM
  #1616
any thoughts/experience on the K3 already?
Old 09-19-2016, 05:27 AM
  #1617
going to get one soon,
but from the people that are running it, its way better on fuel economy when coupled with the new pipe.
on the tracked it seemed exactly the same low end and high end wise as the K5.
Old 09-20-2016, 03:47 AM
  #1618
Mrbigglesworth's Avatar
Looking into getting a K3 for my buggy - have never owned an FX.
I have a bunch of OD97t plugs which I run in my current mills, has anyone tried these in the FX engines?
Mrbigglesworth is offline
Old 09-20-2016, 05:25 AM
  #1619
the FX plugs are just rebanded OS plugs (p3 and p4 etc).
Old 09-21-2016, 01:23 AM
  #1620
I use the OD97T in my K5 with great sucess. The engine does idle great and I had not a single "cut off" during the last 12 liter of fuel.
kapa is offline
