Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
The Official FX Royal Racing Engine Thread >
Like Tree11Likes
Old 05-21-2015, 12:58 AM
  #1486
Originally Posted by morgoth View Post
I saw my new version has a long needle LSN.
Does it tune better/more precise?
i own both and i would say yes, the new one is even slightly better.
throttle response is super clear like it a ton!
gt racing is offline
Old 05-21-2015, 08:12 PM
  #1487
Do you tune any different?
RiPPeN302 is offline
Old 05-21-2015, 11:41 PM
  #1488
Frank L's Avatar
Trader Rating: 148 (100%+)
In my experience long needle carbs will get better mileage and deliver a more balanced throttle response.
Frank L is offline
Old 05-22-2015, 11:43 AM
  #1489
Reno's Avatar
Trader Rating: 16 (100%+)
Can someone tell me the color code for the venturi?
Thanks...
Reno is offline
Old 05-22-2015, 06:29 PM
  #1490
jonw's Avatar
All of the venturi's are black and have the size on them.
Thanks...
jonw is offline
Old 05-25-2015, 07:36 PM
  #1491
Running original FX in truggy and the K5 in buggy. I got nothing but compliments on how strong both sounded all weekend. Running P3 plug currently, going to try P4 next weekend.
Absolute beast with the Werks 2058.
Comparing to the Protek Samurai and Novarossi 4 Port. Found my new favorite!
Cheers
Old 05-26-2015, 02:41 AM
  #1492
first race done, finished 7th in the a-main, was 3rd after quals.
k5 was superrich whole weekend, now 24 tanks done and still mechanical pinch there.
switched to p4 after tank 14.
this engine is money, no questions, tunes like a dream, too much power for this rutted blown track lol
Old 06-09-2015, 12:10 PM
  #1493
morgoth's Avatar
What insert/head shim/manifold+pipe is everybody using to get +10min of runtime?
I run mine with a 6mm insert, 0.4mm shims and 2100 pipe + small medium radius header, but I can't make 10 minutes.
I also have the 2108 pipe with medium radios header.
morgoth is offline
Old 06-09-2015, 11:50 PM
  #1494
Lille-bror's Avatar
Its all about throttle control. A Danish team driver bearly gets 7:30, other +/- 9, I get 9:30 - 10.45 and RobinCH +11 at Bittydesign Contest.
Something that will help mileage a little: You don't need 0.4 mm headshims. Use the stock 0.5. X4 or OS P5 plug. For me, I get identical runtimes wether I run 6mm Mizer venturi or stock 7 mm FX venturi.
Lille-bror is offline
Old 06-10-2015, 12:24 AM
  #1495
morgoth's Avatar
I haven't run my new engine, but the old one had 0.3mm shims by default.
I'm running OS P4 plugs. Do you also run a P5 when it's colder than 20C?
I'm not super smooth, but not aggressive either.
I tried both pipes and while I like the 2100 the most, I think I'm getting more runtime with the 2108.
morgoth is offline
Old 06-10-2015, 05:05 AM
  #1496
finished 3rd in amain last weekend.
2058, 7mm vent.
0,4mm head shim
x4 plug
hot, humid
barely 7 mins in buggy ;(
in the main i had a dry tank just 3 corners before pit stop..
Old 06-10-2015, 06:11 AM
  #1497
Frank L's Avatar
2058, 7mm vent.
0,4mm head shim
x4 plug
hot, humid
Add the head shim to .50mm that will help some with the mileage. You won't notice it anywhere else. Also I would be willing to bet your LSN is 3/4 of a turn too rich.
Frank L is offline
Old 06-10-2015, 06:21 AM
  #1498
thanks frank, will try asap!
Old 06-10-2015, 11:17 AM
  #1499
Lille-bror's Avatar
Oh, the old. As Frank wrote 0.5 is fine with 30% nitro? I run 0.3 in my +20 liter old pre production engine (25% nitro). Started with 0.7, then 0.4 and now 0.3
Did run P5 last year at one race. Temp 10-17C. We have had a very cold spring this year (5-15C) so no P5 yet :-)
Old 06-10-2015, 12:23 PM
  #1500
morgoth's Avatar
I also run 25% nitro.
So 0.5mm is fine with 25% on the new one? I bought one a month ago, but I still need to fine some time to break it in.
My V2 from last year is about 35l old. Just pinched it around 20-22l and it's still going strong :-)
morgoth is offline
