-   Offroad Nitro Engine Forum (https://www.rctech.net/forum/offroad-nitro-engine-forum-157/)
-   -   Pull Start (https://www.rctech.net/forum/offroad-nitro-engine-forum/717087-pull-start.html)
Nathan Wilson 03-27-2013 12:57 PM
Pull Start
can you use a starter box on a pull start car? its a hobao hyper 1/8th buggy. the rubber circle is present and the chassis has a hole in it?
sschultz 03-27-2013 03:30 PM
I the rubber wheel lines up, absolutely you can use a start box...
Alexnailey692 03-28-2013 10:26 PM
If your flywheel is big enough and engine mounts are small enough so not necessarily you might have to buy one or the other or even both I had the same problem with my hpi d8s I had to pay 40 for a new 6mm engine mount
packerbacker 03-28-2013 11:49 PM
He is right. Hopefully they made it where the flywheel is big enough to be hit by the starter box or that the engine mounts don't sit the motor so high it won't contact it.
